No, that is NOT normal. Any relay should be off with the key off. Something is amiss there. The other thing is that a relay is powered with lower amps on the primary side and higher amps on the output side.
is that relay a stock headlight relay? If so, it shouldn't be powered with the key off. If it is a stock "latchable" relay, it shouldn't even light the headlights until the alternator is spinning, then it is "latched" to keep the headlight on. If that is the stock headlight relay, I suspect someone has rerouted some wiring. Maybe the diode was shot and they tried their best to make the headlight work?
