new battery woes
  • Blank Slate
    • Nov 2013
    • 393
    • Ottawa, Ontario, Canada
    new battery woes
    New AGM canadian tire battery. It came charged and worked great at first. Then it died overnight. I cleaned as many connectors as I could find and it worked great again for two days, stayed fully charged. Last night it died again. Goes down to like 10% on the charger needle. Now what should I do? Return battery or do tests on systems?
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
    I would suspect the battery. Quick sanity check is to fully charge the battery, measure the voltage. Then check voltage about once an hour or so for a day. Do this with the battery outside of the bike, on a bench or something. Voltage should NOT drop more than about 0.3V, and most of that will be the first two hours as the battery cools after the charge. If it does drop a lot, battery has an internal short and is bad. I've had a bad AGM, put it in the bike and hit the starter button, everything went out!
    • Blank Slate
      • Nov 2013
      • 393
      Hey Ray, I have a multimeter but what should I set it to? I dont see 12v on it!
      Frame: 79 XS1100S
      Engine: 81 XS1100S
      Carbs: 78-79 BS34
      Gf bike: 78 XS650S
      Carbs: 70-79 BS38
      • Blank Slate
        • Nov 2013
        • 393
        I forgot to mention the weirdest part of all of this . when I connect the charger to the battery the charger does not appear to charge anymore as if there is not a complete circuit.
        Frame: 79 XS1100S
        Engine: 81 XS1100S
        Carbs: 78-79 BS34
        Gf bike: 78 XS650S
        Carbs: 70-79 BS38
          Set it to 20v DC.
          • Blank Slate
            • Nov 2013
            • 393
            i have two chargers and neither can get the new agm battery to charge anymore. worked great at first. hopefully there isnt something wrong in the bike that will kill any new battery i put in.
            Frame: 79 XS1100S
            Engine: 81 XS1100S
            Carbs: 78-79 BS34
            Gf bike: 78 XS650S
            Carbs: 70-79 BS38
              As bikerphil said, set the meter to 20V. Put it on the battery and measure the voltage. Wait two hours and repeat. See if the voltage reading drops.
              For charging AGM batteries, you NEED a charger designed for them. I could not read the big charger to see if it did say AGM on the auto setting. If it does not, it will not charge the battery because it takes a different voltage/charge curve, and the charger doesn't know it. You could put it on 12V., 1Amp manual charge and try that for about five hours. DO NOT try and charge it above 2Amps!
              • Blank Slate
                • Nov 2013
                • 393
                Wow, Ray... the battery didn't come with instructions or anything. they just assume I'm supposed to know this stuff. this is so sad.
                Frame: 79 XS1100S
                Engine: 81 XS1100S
                Carbs: 78-79 BS34
                Gf bike: 78 XS650S
                Carbs: 70-79 BS38
                • Blank Slate
                  • Nov 2013
                  • 393
                  -so yes my trickle charger is an agm approved charger. 0.9A
                  -Cdn tire checking the battery now, they say it’s a good battery but it was “decharged”.
                  -i guess something on the bike is draining the battery.
                  -will do some tests and cleaning of connectors
                  Frame: 79 XS1100S
                  Engine: 81 XS1100S
                  Carbs: 78-79 BS34
                  Gf bike: 78 XS650S
                  Carbs: 70-79 BS38
                    OK, once you get the battery back, do NOT put it in the bike! Test the voltage at the shop when you pick it up, and again about an hour later after you are home. Then check again after about three more hours. The reading should NOT drop more than 0.1 Volt, and no more than 0.05 Volt after you have it home.
                    The trickle charger will charge the battery, but it will take about two days from dead. This is assuming you still show about 8 Volts on the battery.
                      If your battery checks out with Ray’s method and you install it, check for stray currents with your multi meter set on mamps. Pull fuses one at a time and jumper the leads with the meter (replace the fuse each time). This might help you find a starting place for loss of electrons.
                      • Blank Slate
                        • Nov 2013
                        • 393
                        rssults of battery test, bad cell. they will give me a new battery.
                        do i run the tests ray mentioned before putting new battery on?
                        Frame: 79 XS1100S
                        Engine: 81 XS1100S
                        Carbs: 78-79 BS34
                        Gf bike: 78 XS650S
                        Carbs: 70-79 BS38
                          I would if you don't mind spending a few hours before the install. But, when the first battery did the same thing on me, after the replacement got here I just installed it and rode away. I figured they were going to be SURE the replacement was good.
                          • Blank Slate
                            • Nov 2013
                            • 393
                            3pm 12.70
                            4pm 12.67
                            5pm 12.67
                            7pm 12.68
                            new battery seems good?
                            Frame: 79 XS1100S
                            Engine: 81 XS1100S
                            Carbs: 78-79 BS34
                            Gf bike: 78 XS650S
                            Carbs: 70-79 BS38
                              Good catch! There is too much crap being sold.
