new battery woes
  • Blank Slate
    • Nov 2013
    • 393
    • Ottawa, Ontario, Canada
    i agreed with your post. i think im doing what you guys suggest and im sure the multimeter is fine, hardly ever use it and its a year old. ill check it out and see to be sure
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
      You're doing fine, even excellent!
      Almost all of the electrical system should be completely dead when the ignition switch is off. Before you remove the fuel tank, just pull all of the fuses except the Main fuse, then hook up the battery to see if anything is clicking.
      If nothing clicks, put the fuses back in one at a time.
      • Blank Slate
        • Nov 2013
        • 393
        i removed gas tank and found the clicking sound.
        when i disconnect it, there is no more clicking.
        Frame: 79 XS1100S
        Engine: 81 XS1100S
        Carbs: 78-79 BS34
        Gf bike: 78 XS650S
        Carbs: 70-79 BS38
        • Blank Slate
          • Nov 2013
          • 393
          #34
          its called a relay assembly 360-81950-10-00
          Frame: 79 XS1100S
          Engine: 81 XS1100S
          Carbs: 78-79 BS34
          Gf bike: 78 XS650S
          Carbs: 70-79 BS38
            Nice find! That is the correct headlight relay, if it's clicking when the battery is connected but the ignition switch is off, there is a short circuit somewhere.
            Do the headlight and the tachometer work?
            Does the voltage at the battery go up when you run the engine around 2,000 RPM?
            In the '78/'79 models, the headlight relay gets its power from the center-tapped Yellow neutral wire from the alternator. IF the ignition switch is good and no one has hacked the original wiring harness, the output isolation diode on the voltage regulator might have failed and the battery is discharging through the stator coils to ground and the headlight relay.
            Disconnect the voltage regulator/rectifier and check the diodes.
            [url=http://www.xs11.com/forum/showthread.php?t=29251]
            link: http://www.xs11.com/forum/showthread.php?t=29251
            XS11 .com Forums > Idle Talk Forum > XS11/XJ11 Discussion
            Best way to check if a regulator/rectifier is going bad?
            [/url
              • 735
              79sf frame - 81sh engine
              You signature indicates you have a 79 sf frame with an 81 sh engine. Do you know which wiring harness you have? The 79 or the 81? I'm not positive but I think there are some electrical differences . Perhaps that information might help electrical guru's here who are trying to help you.
              • Blank Slate
                • Nov 2013
                • 393
                #37
                I'm pretty sure it's a 79 wiring harness. the only things that are 81 are the engine with the TCi for the 81 engine. everything else is 79 special.
                Frame: 79 XS1100S
                Engine: 81 XS1100S
                Carbs: 78-79 BS34
                Gf bike: 78 XS650S
                Carbs: 70-79 BS38
                  That's not a problem.
                  DO THE HEADLIGHT AND TACHOMETER WORK?
                  DOES THE VOLTAGE GO UP WHEN YOU RUN THE ENGINE AROUND 2000 RPM?
                  • Blank Slate
                    • Nov 2013
                    • 393
                    #39
                    Tachometer was not working yesterday. it bobbled around 0 rpms the whole time.
                    headlight was not running with key on, but i believe engine has to be on for it to work. ill check tonight. ill also check what happens at 2,000 rpms.
                    Frame: 79 XS1100S
                    Engine: 81 XS1100S
                    Carbs: 78-79 BS34
                    Gf bike: 78 XS650S
                    Carbs: 70-79 BS38
                      I'm going for a ride on my XJ so I'll be out on the road for a few days, I'll try to check in later tonight.
                        Hi Scott,
                        I do enjoy your posts. Like this one.
                        I'm going for a ride...could be gone for days or weeks
                        Fortunately for us there is wifi all over the place these days.
                        Have fun.
                          • 7832
                          Hey Phil, remember, Scott is almost as old as I am, so without a computer it's hard to read the emails! I know I DON'T do email on the phone for that reason.
                            Thanks, Phil, riding is more fun than wrenching any day and, like Ray, I don't do e-mail on my phone if there's any way to avoid it. I got distracted one time trying to ffool with it, now the phone or the data feature gets turned off while I'm on the road.
                            Pablo, how's the battery, charging, and lighting system doing?
                            The headlight relay and the tachometer are both connected to the alternator. If the headlight relay clicks when you connect the battery with the ignition off and tach isn't broken -- not a safe assumption -- but doesn't work when the engine is running then the charging system is probably not working either. It's almost as good as having a volt/ammeter or an idiot light.
                            • Blank Slate
                              • Nov 2013
                              • 393
                              #44
                              As a temporary fix, I moved the headlight relay to the outside, I wanted to be able to unplug in between rides so the batery wouldn’t drain. It turns out that when everything is plugged in but bike is off and no key in ignition, this thing gets really hot! Is this normal or concern?
                              Frame: 79 XS1100S
                              Engine: 81 XS1100S
                              Carbs: 78-79 BS34
                              Gf bike: 78 XS650S
                              Carbs: 70-79 BS38
                                Right on! That's one way to fix it.
                                No, the headlight relay is not supposed to switch on until the engine starts and the alternator begins charging but it will get hot when it's switched on.
                                To see if it's something simple like a bad voltage rectifier diode you just disconnect the battery, then unplug both connectors for the voltage regulator/rectifier and reconnect the battery to see if the relay still clicks.
                                The voltage regulator/rectifier has two electrical connectors and it's bolted at the top of the frame underneath the fuel tank right next to the rear fuel tank mount.
