new battery woes
    • 7819
    New battery seems good. You will know after one or two starts. Mine didn't show up until I tried to start it the first time. About 1/2 rev and no lights!
    • Blank Slate
      • Nov 2013
      • 393
      • Ottawa, Ontario, Canada
      after charging all night, it was 13.29 this morning. im going to ride to work, 30 min city ride, go home around 2pm, and see what the charge is tonight.
      Frame: 79 XS1100S
      Engine: 81 XS1100S
      Carbs: 78-79 BS34
      Gf bike: 78 XS650S
      Carbs: 70-79 BS38
      • Blank Slate
        • Nov 2013
        • 393
        One thing I noticed and I don't know if it's a concern or not. When I try to hook up the battery connectors, I connect the positive one first, then I hook up the negative one. I notice that there is a click click sound coming from underneath the gas tank, about where the carbs are, when I'm trying to connect the black cable to the battery. Once I have it connected the click noise is gone.
        Frame: 79 XS1100S
        Engine: 81 XS1100S
        Carbs: 78-79 BS34
        Gf bike: 78 XS650S
        Carbs: 70-79 BS38
          • 5073
          Maybe a solonoid switch? I think the auxiliary lugs under the right side cover are aways hot...you don’t have anything hooked to it do you? I would think that there should be nothing else hot without turning the key (I don’t know about emergency flashers on later bikes). I wonder if the key switch needs some cleaning? I would pull the 30 amp main fuse and check for current across it.
            • 8894
            I would check for a current drain with the key in the off position. Connect the positive cable to the battery. With the negative disconnected, put one multimeter lead on the neg cable and the other on the neg post of the battery. Set your meter to 10A setting and you may or may not have to switch the red lead on your meter over to the other connection marked 10A. There should be no voltage draw on the meter. If there is, report back.
            • Blank Slate
              • Nov 2013
              • 393
              biker phil,
              i did what you said and took many readings. sometimes it starts in the teens, 30’s, 70’s, but one constant thing is that the numbers keep going up! 15,16,17,18,19
              35,36,37,38,39
              79,80,81,82
              etc....
              i put the multimeter on 10A DC.
              key in off position
              disconnected the negative cable
              put one end of meter on battery neg port, and one end on the negative cable.
              also i took a reading of the battery and it’s at 12.87.
              Frame: 79 XS1100S
              Engine: 81 XS1100S
              Carbs: 78-79 BS34
              Gf bike: 78 XS650S
              Carbs: 70-79 BS38
                • 8894
                key in off position
                put one end on battery neg port, and one end on the negative cable.
                Did you also plug the red wire into the meter port that is marked 10A? I'm not understanding the numbers/readings you posted.
                • Blank Slate
                  • Nov 2013
                  • 393
                  my apologies
                  the clicking sound is definitely coming from key ignition area. maybe headlight
                  Frame: 79 XS1100S
                  Engine: 81 XS1100S
                  Carbs: 78-79 BS34
                  Gf bike: 78 XS650S
                  Carbs: 70-79 BS38
                  • Blank Slate
                    • Nov 2013
                    • 393
                    no lol
                    let’s try again
                    reading now
                    -1
                    and if i flip the meter ends and measure
                    - . blinking very fast
                    Frame: 79 XS1100S
                    Engine: 81 XS1100S
                    Carbs: 78-79 BS34
                    Gf bike: 78 XS650S
                    Carbs: 70-79 BS38
                      Batteries keep discharging
                      Is the headlight on?
                      If the headlight relay is kicking in when you connect the battery and the ignition switch is OFF, that would drain the battery even if the headlight doesn't turn on.
                      Unless someone's been into the wiring there is absolutely nothing on a '79 Special that is anywhere near the ignition switch or the headlight shell that will click, clack, beep, boop, or make any other sound except the horns or the headlight relay.
                        • 8894
                        If there is some sort of current drain, you would see a reading of (ex.) 0.15, 1.25 etc. if there is no reading there is no draw. Only other thing possible is the 10A fuse in the meter is blown.
                          Hey Blank, and others,
                          Just some info regarding your battery charger. There's nothing wrong with it, even though you had a bad battery, even if the battery was good, BUT DISCHARGED to 10 or less volts, no modern charger will charge, because it THINKS the battery already has a dead cell.
                          To charge a severely discharged battery, you need to put it in PARALLEL with a GOOD (12+V) charged battery. THEN the charger will sense the 12 volts, and not just the 10 or less of the drained battery and will then send a recharging current to both batteries. The charged one won't need it, so it'll go into the discharged one. Monitor it for a few hours UNTIL you see the voltage get to ~11V, then you can take the spare good battery OFF of the parallel connection/circuit and directly charge the bad battery with the charger!
                          • Blank Slate
                            • Nov 2013
                            • 393
                            Im pretty sure i disconnected the horn because i had to pass some cables and the horn was in my way.
                            should i disconnect the headlight relay to see ifthe clicks and draining stop?
                            Good info TC!
                            Frame: 79 XS1100S
                            Engine: 81 XS1100S
                            Carbs: 78-79 BS34
                            Gf bike: 78 XS650S
                            Carbs: 70-79 BS38
                              • 5073
                              Posts 21, 22, and 26 do not seem to be resolved. You just can’t get higher amp readings than 10 amps if the meter is set correctly, working correctly and the test leads are in the right ports. Is the headlight switchable or is it automatic and stock? I am just wondering if someone has put in a relay switch that isn’t oem and somehow connected to a hot wire. You might be able to track down the clicking sound with the tank off. You need a working multimeter and need to know how to use it (if you are not sure) to help you track down to stray current. You might be able to clean up the ignition switch if there is a lot of gunk and copper smears in it and make it work if that is the problem.
                                • 5073
                                PS, I meant not disrespect by my previous post. Just trying to help...
