MNS carbs
    MNS carbs
    Do I need to be careful with the black MNS carbs in the dip bucket or is the black tough enough to take it?
    Never done an actual set of MNS carbs but I'm about to.
    I would use an ultrasonic cleaner with pinesol rather than a dip bucket. I don't think the black will stay on in the solvent, plus you will be doing all the rubber seals as well.
      • 2104
      Hey Greg,
      I dipped my XJ 750 Midnight Maxim carbs in straight Pine-Sol for three days and upon removal, the paint, in places, peeled off so you may not want to soak 'em that long
        OK. Thanks y'all.
        • mack
          • 2411
          • Ontario, Canada
          MNS Carbs
          I did three sets of these Greg and used an aluminum safe cleaner in my ultrasonic Branson 8510. The product I used was "Crystal" but really its a Branson knock off. You can't ship chemicals across the border without doing a truck load of paperwork so this was the Canadian version. You can go to the branson web and order the real stuff. I gallon jug lasts forever because you only put 1 cup per gallon of water and can reuse it several times. Doesn't hurt the paint or the aluminum and cleans electrical contacts to like new condition. Won't hurt the butterfly shaft seals at all.
          Just pull your components out of the tank. Rinse in water and blow dry.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
          • BillyRok
            • Aug 2011
            • 421
            • Shortsville, NY.
            Here is a brochure for Branson cleaning products...page 4 is a summary of effects on various metals.
            Mack, which of these is like the knock off you used? Would like to soak my LG carbs also.
            Billy
            • mack
              • 2411
              • Ontario, Canada
              Branson
              I believe the Crystal we have up here conforms to the MC-1 standard. It's safe on everything including butter fly shaft seals. makes the copper contacts in the handlebar controls look brand new. I put my transmission gear shafts in it to clean out the oil ports and look for defects in the gears themselves before assembly.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
              • mack
                • 2411
                • Ontario, Canada
                Branson
                I'd contacted Branson directly and tried to place an order and they were the ones who told me about the shipping restrictions and gave me their Canadian affiliate. When I was restoring "Blank Slates" SF, he was astonished at how well it worked. He went out and bought a Branson of his own and uses it on everything around his place. Cleaning everything from old tools to the chrome on his stove. LOL
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
