This might be of interest to some. I had to drill out a idle mixture screw on one of my carb bodies but some of the brass threads stayed firmly imbedded in the carbs grooves. I couldn't find the correct reamer in standard tap and dye sets and talked with several tool suppliers like "snap on" etc. and was told they aren't stocked. I gave the problem to my nephew who is a millwright. He promptly measured the jet and special ordered one from his supplier and cut the taper off the bottom and reground the cutting flute edges. It worked like a charm. The spec on this is M6 with thread pitch of 0.5 and a depth of 0.04. I ordered three more and will make them available if anyone else finds themselves in a similar situation.
80/81 carbs
80/81 carbs
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
McMaster Carr. Search for tap 6mm .5 pitch. Best choice is the tap designed for aluminum and brass. Must be hand turned.1995 KZ100P
Pods, jets, pipes, cam adjuster, oil cooler
1977 Ironhead - custom build
Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.Comment
I can only imagine the cost, what about rental ? ? ?This might be of interest to some. I had to drill out a idle mixture screw on one of my carb bodies but some of the brass threads stayed firmly imbedded in the carbs grooves. I couldn't find the correct reamer in standard tap and dye sets and talked with several tool suppliers like "snap on" etc. and was told they aren't stocked. I gave the problem to my nephew who is a millwright. He promptly measured the jet and special ordered one from his supplier and cut the taper off the bottom and reground the cutting flute edges. It worked like a charm. The spec on this is M6 with thread pitch of 0.5 and a depth of 0.04. I ordered three more and will make them available if anyone else finds themselves in a similar situation.
76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'eComment
Well
I didn't think $7.00 was out of line, when the alternative is toasting a good carb body. Like I said I had the taper cut off to hit bottom and the flutes reground to pop the brass out of the grooves shoulders. My nephew is a machinist and I showed him what I wanted and why. He never charged me anything because I have his wife's name for Christmas and will buy her something very nice: but, you try to get a custom tool for $7.00. My offer still stands. My intent, with Scott's permission of course, I would send one to 3 Phase and he can mail to whoever needs one and tracks the mailing back and forth so it doesn't get lost. On the other side I will send one to Billyroc for the north eastern US. The goal here is to help one and other. I ask nothing in return.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
That Sir is as generous as anyone on any forum could be. Seems Yamaha forums of which XS11 and XS650 (my only experience) have the greatest people involved.I didn't think $7.00 was out of line, when the alternative is toasting a good carb body. Like I said I had the taper cut off to hit bottom and the flutes reground to pop the brass out of the grooves shoulders. My nephew is a machinist and I showed him what I wanted and why. He never charged me anything because I have his wife's name for Christmas and will buy her something very nice: but, you try to get a custom tool for $7.00. My offer still stands. My intent, with Scott's permission of course, I would send one to 3 Phase and he can mail to whoever needs one and tracks the mailing back and forth so it doesn't get lost. On the other side I will send one to Billyroc for the north eastern US. The goal here is to help one and other. I ask nothing in return.
I have a set of LG/LH carbs on/in the corner of my bench with a pilot jet in one carb that will not budge, so I could use one of these tools that afterwards I would make available to whomever needs it on a loan basis.
If this is acceptable where do I send money, address please (Paypal, if so an email address).76 XS650 C ROADSTER
80 XS 1100 SG
Jets
this is for the idle mixture jet only. However I went to "snap on" and bought a left handed set of drill bits and have removed hundreds of pilot and main jets with them. You should buy yourself a set. They were only about $18 if my memory serves me right. The set also has easy outs with it as well.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
Should have looked closer at the post, myself to blame. Thank You for the heads up on Snap Onthis is for the idle mixture jet only. However I went to "snap on" and bought a left handed set of drill bits and have removed hundreds of pilot and main jets with them. You should buy yourself a set. They were only about $18 if my memory serves me right. The set also has easy outs with it as well.76 XS650 C ROADSTER
80 XS 1100 SG
I can do that, no problem.I didn't think $7.00 was out of line, when the alternative is toasting a good carb body. Like I said I had the taper cut off to hit bottom and the flutes reground to pop the brass out of the grooves shoulders. My nephew is a machinist and I showed him what I wanted and why. He never charged me anything because I have his wife's name for Christmas and will buy her something very nice: but, you try to get a custom tool for $7.00. My offer still stands. My intent, with Scott's permission of course, I would send one to 3 Phase and he can mail to whoever needs one and tracks the mailing back and forth so it doesn't get lost. On the other side I will send one to Billyroc for the north eastern US. The goal here is to help one and other. I ask nothing in return.
So far (knocks on wooden head) I haven't mangled any carburetor bodies, just pilot jets, but you never know.
♬Comment
