80/81 carbs
  • mack
    • 2411
    • Ontario, Canada
    80/81 carbs
    This might be of interest to some. I had to drill out a idle mixture screw on one of my carb bodies but some of the brass threads stayed firmly imbedded in the carbs grooves. I couldn't find the correct reamer in standard tap and dye sets and talked with several tool suppliers like "snap on" etc. and was told they aren't stocked. I gave the problem to my nephew who is a millwright. He promptly measured the jet and special ordered one from his supplier and cut the taper off the bottom and reground the cutting flute edges. It worked like a charm. The spec on this is M6 with thread pitch of 0.5 and a depth of 0.04. I ordered three more and will make them available if anyone else finds themselves in a similar situation.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 5062
    You lucked-out having an expert available to help!
    • Aches n Pains
      • 349
      • Reston, Va.
      McMaster Carr. Search for tap 6mm .5 pitch. Best choice is the tap designed for aluminum and brass. Must be hand turned.
      1995 KZ100P
      Pods, jets, pipes, cam adjuster, oil cooler
      1977 Ironhead - custom build
      Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
      Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        I can only imagine the cost, what about rental ? ? ?
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
        • mack
          • 2411
          • Ontario, Canada
          Well
          I didn't think $7.00 was out of line, when the alternative is toasting a good carb body. Like I said I had the taper cut off to hit bottom and the flutes reground to pop the brass out of the grooves shoulders. My nephew is a machinist and I showed him what I wanted and why. He never charged me anything because I have his wife's name for Christmas and will buy her something very nice: but, you try to get a custom tool for $7.00. My offer still stands. My intent, with Scott's permission of course, I would send one to 3 Phase and he can mail to whoever needs one and tracks the mailing back and forth so it doesn't get lost. On the other side I will send one to Billyroc for the north eastern US. The goal here is to help one and other. I ask nothing in return.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            That Sir is as generous as anyone on any forum could be. Seems Yamaha forums of which XS11 and XS650 (my only experience) have the greatest people involved.
            I have a set of LG/LH carbs on/in the corner of my bench with a pilot jet in one carb that will not budge, so I could use one of these tools that afterwards I would make available to whomever needs it on a loan basis.
            If this is acceptable where do I send money, address please (Paypal, if so an email address).
            76 XS650 C ROADSTER
            80 XS 1100 SG
            • mack
              • 2411
              • Ontario, Canada
              Jets
              this is for the idle mixture jet only. However I went to "snap on" and bought a left handed set of drill bits and have removed hundreds of pilot and main jets with them. You should buy yourself a set. They were only about $18 if my memory serves me right. The set also has easy outs with it as well.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                Should have looked closer at the post, myself to blame. Thank You for the heads up on Snap On
                76 XS650 C ROADSTER
                80 XS 1100 SG
                  I can do that, no problem.
                  So far (knocks on wooden head) I haven't mangled any carburetor bodies, just pilot jets, but you never know.
