Another problem question I created with fuel tank
  • dolphans1
    • Mar 2013
    • 168
    • Orlando, Fla.
    OK guys, I created another problem. I have always kept the fuel Trank full and I’m getting ready for a buddy to paint my fuel tank. I emptied the fuel and my fuel tank looked beautiful inside. Bye then rinsed it out with hot water and a bunch of sludge kind of algae material came out along with a couple leaves believe it or not but other than that the inside the tank look clean like brand new. I told my buddy I was worried about rust or flash rusting And should I pour some kerosene in the tank and slush around to keep it Oily. I was told it would be okay. Well the very next day I went by and looked at the tank and it’s got flash rust all in it. Should I used red cedar vinegar or Metal Rescue ? Has this happened to anyone before? What worked for you?
    79 SF
  • sethhope
    • May 2016
    • 226
    • Springfield, MO
    I had this when i painted my tank. Im not sure how good it is for anything, but i just sloshed some vinegar in and it seemed to clear out ok. I recommend treating with kerosene after to prevent more flash rust. More experienced guys are welcome to weigh in here.
    1979 XS1100F "Roxy" (my first bike ) - '91 Suzuki GSX1100 Fairing, BMW bags, Cheap ABS Trunk, aftermarket cruiser seat, MAC 4-2 exhaust, Heavy Duty folding kickstart, XS11 Special signals and gauges, Blade Fuse Conversion, Dynacoil Greens w/ ballast bypass, SS brake lines
    • dolphans1
      • Mar 2013
      • 168
      • Orlando, Fla.
      I read and heard coating it is not good because over time it starts to peel off. Acid wash will damage petcock seals.
      79 SF
      • dolphans1
        • Mar 2013
        • 168
        • Orlando, Fla.
        I also read conflicting reports on amount of fuel the tank holds, anywhere to 4 gallons to 5 to slightly under 4 gallons. Nothing is ever easy in life.
        79 SF
          • 724
          I’ve had good success on several different tanks with Evapo-Rust. It will make the tank shiny and new again but it is bit pricey. However it can be saved and used over and over again multiple times.
          After cleaning the tank with Evapo-rust, it should be rinsed and dried thoroughly. (rinsing with acetone works well for removing all residual moisture)...Then after dry, immediately coat with an oil base coating of some sort to prevent re-flashing. I have tried different stuff … fogging oil, WD-40, 2 cycle oil, and even sea foam, all of which seemed to work fine. Fogging oil spray was probably the easiest to use. Allow excess oil coating to drain out.
          • dolphans1
            • Mar 2013
            • 168
            • Orlando, Fla.
            Thanks Ranger and Seth, did you use 4 gallons of Evapo Rust, about how much was it did you fill it to the brim?
            79 SF
              • 724
              I have found that a special tank which is stated to have a 3.9 gallon fuel capacity on the bike, will hold aprox 5 gallons of evapo-rust when off of the bike and propped up to fill the front cavity.
              • dolphans1
                • Mar 2013
                • 168
                • Orlando, Fla.
                Flash rust
                after 2.5 gallons of hot water flush
                after 2nd rinse of hot water the water was clear when it came out
                The tank held 4 gallons of cedar vinegar to the edge of brim, going to let it sit for 2 days and report back.
                79 SF
                  • 724
                  oops!, I must have been thinking about the standard tank then when I stated 5 gallons!, sorry about that.
                  • dolphans1
                    • Mar 2013
                    • 168
                    • Orlando, Fla.
                    there are some tanks over the pond that hold 5 gallons, that I read but never seen, I guessed 3.5 until I actually checked.
                    hard to tell but the tank is full here. about $16.00 for 4 gallons of vinegar, also purchased acetone and oit fog by stabil.
                    79 SF
                    • MPittma100
                      • Aug 2011
                      • 2359
                      US Bike Tank Capacity
                      Specials - 4 gal
                      Standards - 5 gal
                      Venturer - 6 gal
                      Depending on whose book you are reading, you will see numbers like 3.9 gal, 5.1 gal, etc.
                      I was told by a UK member that all of the UK Standards had the 6 gal tank.
                      1981 XS1100H Venturer
                      K&N Air Filter
                      ACCT
                      Custom Paint by Deitz
                      Geezer Rectifier/Regulator
                      Stebel Nautilus Horn
                      EBC Front Rotors
                      Limie Accent Moves On In 2015
                      Mike
                      • dolphans1
                        • Mar 2013
                        • 168
                        • Orlando, Fla.
                        That 6 gallon tank would be useful for long rides, but would also add some extra weight to the bike.
                        79 SF
                        • sethhope
                          • May 2016
                          • 226
                          • Springfield, MO
                          Flash rust
                          Wow ive gotta look into evapo rust! That stuff looks pretty good. Maybe ill treat my tank with it this year when i do my yearly carb clean.
                          • MPittma100
                            • Aug 2011
                            • 2359
                            Tannk
                            In 1981, Yamaha put the 6 gallon tank on the Venturer (Standard). One year only.
                            K&N Air Filter
                            ACCT
                            EBC Front Rotors
                            Mike
                              • 7860
                              If you acid etched your tank with vinegar, it will quickly rust again, or you may install a liner.
                              Yes, a liner will fail if not properly installed. I favor the Caswell epoxy liner. That one is most forgiving and won't fail if done properly. Mess it up and your tank is junk as no solvent will dissolve that epoxy AFAIK.
