Another problem question I created with fuel tank
    • 2104
    Looks Good !!!
    Tank looks good and clean, nice job.
    It's a good idea to use inline filters also just in case of any small debris that got missed in the flush.
    • dolphans1
      • Mar 2013
      • 168
      • Orlando, Fla.
      Thanks Schming, but where would I install an inline fuel filter when there is 2 hoses per petcock om each side, would I install 1,2,3, or 4?
      Thanks.
      79 SF
        • 2104
        Install filters after the "Octy" before the carb tees.
        • dansmith65
          • Aug 2017
          • 141
          • Kootenays, BC , Canada
          #34
          Is that so you can switch to prime to bypass them in case of a clog/restriction in the filter? I was contemplating the same question recently and that was my reasoning for considering that location.
          80 SG Canada
            • 2104
            Ideally the filters should be in the lines coming from the octy to the fuel feed tees to filter all fuel from the tank regardless of the petcocks valve position.
            • dansmith65
              • Aug 2017
              • 141
              #36
              Now I see what you mean. I was thinking of the wrong tee when you said "fuel feed tees". To clarify, your suggesting cutting #3 to add a fuel filter, in this image: https://www.partshark.com/oemparts/a...el-cock-piping
              Previously, I was considering putting them at #7 and 8, so I could keep riding in spite of fuel filter issues (restriction/clog/whatever).
              80 SG Canada
                • 2104
                Correct #3 on left and right sides are the ones to cut and install filters.
                If you find straight filters won't let the fuel lines flow properly (kink) here is a link to 90 degree filters.
                https://www.ebay.com/itm/YAMAHA-ATV-...53.m1438.l2649
                  #38
                  I gotta say, those porous stone filters are lousy. I use the Fram inline filters.
                    • 2104
                    The filters in the link I provided have either a polyester or 304 SS element.
                    Porous Sintered Bronze may be what you are mistakenly calling porous stone.
                    I don't care for them either.
                    Here's a link to some specs: https://www.industrialspec.com/shop/...l-filters.html
                      They work fine for me. Then again, there's no crap in my tank.
                      • dolphans1
                        • Mar 2013
                        • 168
                        • Orlando, Fla.
                        #41
                        Promised Photos of tank
                        79 SF
                        • dolphans1
                          • Mar 2013
                          • 168
                          • Orlando, Fla.
                          #42
                          Repost of images of flash rust I created and disappeared.
                          This is 2nd flush out with hot water.
                          79 SF
                          • dolphans1
                            • Mar 2013
                            • 168
                            • Orlando, Fla.
                            #43
                            79 SF
                            • dolphans1
                              • Mar 2013
                              • 168
                              • Orlando, Fla.
                              #44
                              This Photo is picture of vinegar full to the gas tank filler neck
                              79 SF
                                • 3193
                                #45
                                Just a thought here but if you let a little of the vinegar out and slowly topped the tank with oil, then let it settle a few moments. As oil will rise to the top over vinegar it should stabilize at the top. Now if you were to drain the tank from the petcocks slowly, would not the oil coat the tank as the fluid drained?
                                Would the vinegar still keep reacting or would it stop? I dunno but it makes me think.
