octy just crapped out on me...freaked out now...
    • 7860
    Originally posted by BA80
    If it's leaking BETWEEN the carbs it's not getting into the oil. The rubber on the t's is bad.
    Marty, you posted up the t repair in repairs but the pics are all gone. You know, peel the old rubber off and use o rings to repair it? I've used that several times and it works well and haven't had a failure yet.
    I've done it both on Okie and The Hornet.
    Maybe you still have those pics somewhere and can guide him through it.
    BikerPhil did that repair. I bought new brass tees from Sirius Consolidated, Inc. BikerPhil is still active here, right?
      • 9980
      I just peeled the old rubber back far enough on the original tees for a couple of nitrile o rings on BOTH ends and it works great.
      A little silicone grease so they slide in easy and BINGO! No more leaky tees.
        • 9980
          • 8766
          Yep, I'm still here Marty. I had one of those O ring repairs fail on a members bike, the bike does not see much use and the O rings dried out and failed. I won't use HF O rings anymore.
          07 Triumph Tiger 1050
          • ERM83
            • Apr 2016
            • 314
            • Lehigh Valley, PA
            sorry, I gotta word this better...
            Ok, here's what I mean:
            The connection from the petcock, TO A TEE FUEL-FITTING, in which THE STRAIGHT PART goes to the octy, AND THE BOTTOM PORT OF THAT SAME TEE connects VIA A FUEL LINE to THE BOTTOM FUEL TEE on the carbs. I remove THE TOP TEE SETUPS from THE BOTTOM TEE SETUPS so that I can just keep the tubes together, and cleanly yank the ol' carbs. I just cleaned up the TEE's a few months ago...no problems there at all! PRISTINE.
            In the manual, it says when removing the carbs to put the petcocks on the "on" or "res" position. I always just turn them off. However, I DON'T remember i'd ever had that petcock ON when I yanked the carbs.
            That brings me to: when checking for leaks, after the carbs were OFF THE BIKE, I turned the petcock ON to see if fuel would come OUT OF THE TOP TEE (bottom port) fuel feed that feeds to the BOTTOM CARB BOWL TEE. and it indeed did come FLYING out of there, and I couldn't remember if it SHOULD...or if it shouldn't be feeding any fuel from that petcock port unless the bike was running and had vaccum??? See what I mean??
            I'm starting to think that I just had dirty carbs, and I'm FREAKING OUT about something rather trivial, haha.
            Sorry about that...I definitely wasn't very clear. I was WAY TIRED when I made most of these posts!!
            80' XS1100 SG "Dottie"
            79' SF carbs
            MAC 4-1
            K&N Pods
            Accel 3.0 coils
            Tarozzi fork brace
            TC fusebox
            Picture update soon
            http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
            79' XS1100 SF (parts, will be reborn)
            http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
              • 9980
              Are you saying there at 2 tee setups on each pair of carbs? An upper tee and a lower tee?
                • 8766
                I think he means the T's for the octy hoses, not the ones in between the carbs themselves, they are not leaking.
                • mack
                  • 2411
                  • Ontario, Canada
                  Ba80
                  mack
                  79 XS 1100 SF Special
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  https://youtu.be/wB5Jfbp6SUc
                  https://youtu.be/RaI3WYHSuWA
                  Frankford, Ont, Canada
                  613-398-6186
                  • ERM83
                    • Apr 2016
                    • 314
                    • Lehigh Valley, PA
                    YES, THAT'S what I meant! I didn't mean to be confusing, sorry guys!!
                    I just didn't know if they (the top tee octy lines) were supposed to feed fuel while on the ON position WITHOUT vacuum (aka, engine started), or if they just fed fuel to the carbs, and the ACTUAL CARBS only fed fuel to the engine when it was running (WITH vacuum). I thought that line was only supposed to feed fuel like that in the "prime" position?? Either way, I'm on my way (1.5 mile walk...) to pepboys now for oil and random stuff. Hopefully they have inline fuel switches in stock...
                    79' SF carbs
                    MAC 4-1
                    K&N Pods
                    Accel 3.0 coils
                    Tarozzi fork brace
                    TC fusebox
                    Picture update soon
                      • 7860
                      Yes, those tees above the carburetors always have fuel as the taps on the tank will always flow whether PRIME or ON. PRIME should be plumbed to allow you to bypass the shutoff valve.
                      I replaced those tees with brass ones from my local hardware store. It's all been working fine for a few years now.
