Spectras 1100 and questions......
  • spectra
    • Aug 2017
    • 113
    • Vancouver, WA
    Ok am going to have a lot of questions so may as well start a thread in here..........working on getting it running right first but at the same time other things to.
    New Dyna coils showed up today so mounted them and also added new wires and plugs. Fired right up but still had a little miss......
    New Jets showed up today but waiting on floats. Found two that were crushed a little so a new set is on the way.
    Ok have new shoes going on the XS this week so pulled the wheels and dismounted the tires and going to re paint the wheels before hand. Question is what to look for as I have things apart......I am going to also re place the pads and go over all the calipers as I have re build kits just in case.
    Fork seals are in need so am going to do that also.
    Should I pull the rear drive now as it seems like the thing to do since its so easy? Clean up the splines and re grease everything ?
    These 1100s are new to me and actually like the way the rear wheel came off. Much easier than the chain drives......
    Now looking at new exhaust as my 4 into 1 does not allow me to use the center stand.......I don't like that. Looking at MAK 4 into 1 or is there better out there? The one I have now has been bottomed out and has a 3" crack in one pipe. I could weld it up but is it even worth it?
    79 SF
    Can pull the drive for clean up and regrease splines if your so inclined.
    actually that is what that grease zerk is for on the driveline housing. Two of us here(Captain Zap and I) have proven that zerk angle and location is more than sufficient for shaft spline lubrication. I might add, my shaft tube assembly has NEVER been off since I bought the Venturer new in 1981. Bike now has 83K miles of use,,,,mostly long distance rides.
    • spectra
      • Aug 2017
      • 113
      • Vancouver, WA
      I have thought of doing that. I am anal and would rather pull it all apart and grease it with what I like than add to the mess
      I want to tear this thing down to the frame but........its a beast so will just go with what I am doing.
      79 SF
        • 9980
        The Mac 4 into 1 with the flare tip mufflers is the way to go with Mac. The flare tip mufflers are the only ones that have have removable baffles.
        I had to modify the baffles because the ones Mac uses are too restrictive. For my 79 engine anyway.
          • 8051
          I haven't really been following your journey. I'll jump in with my two cents anyway.
          Is the bike new to you?
          Grease the swingarm bearings. It has probably never been done.
          The upper steering head bearing is likely dry. Grease upper and lower.
          One you replace the fork seals, get in the habit of replacing the fork oil routinely. It should probably be done about every third engine oil change. Not doing so will accelerate fork slider wear. New bikes have hard anodized sliders. The XS1100 does not.
          Brake fluid should be placed annually.
          Much of what needs to be done is intuitive. There is a list in the service and/or owners manual.
          Best wishes!
          • spectra
            • Aug 2017
            • 113
            • Vancouver, WA
            http://www.xs11.com/forum/showthread...ght=power+loss
            That is what I was looking at the 4 to 1 with removable baffle. It says center stand does not need to be modified so that's what caught my eye.....I want a center stand.
            Best wishes!
            Thanks for the heads up and yes bike is new to me. Picked it up with a few issues. Hopefully those are almost fixed.
            I was planning on cleaning up the shaft drive and re greasing everything on it. Need to go through the brakes so new fluid is a must.
            I agree on the head bearing as the last 2 400s I did were dry and crusty......
            79 SF
              • 9980
              My bad, I meant to say the 4 into 2. I had a 4 into 1 Mac on my SF and even though it says you don't need to remove the center stand, it has to come off.
              • spectra
                • Aug 2017
                • 113
                • Vancouver, WA
                Yes I was wondering........I have a 4 into 1 super trap and love the sound except for the leaks where its cracked Oh well I actually like the 4 to 2 better but wanted black......all I can find is chrome. I am not one to polish things
                Looks like I may be stuck with the chrome though.........also the pipes turn no matter what and that's what really bugs me.....
                79 SF
                • Barbarosa
                  • Jun 2009
                  • 135
                  • Fayetteville, AR
                  [QUOTE=spectra;502760]That is what I was looking at the 4 to 1 with removable baffle. It says center stand does not need to be modified so that's what caught my eye.....I want a center stand.
                  I have a 4-1 (something or other) exhaust and like the center stand too, but wouldn't haul one around even if I could. When I need to lift the bike I mount the stand, slide the bolts through, and up she goes. No spring or nuts needed. Probably takes a whole minute to get on and off. Guessing you could just carry one along if it was an absolute necessity.
                  1980 xs1100SG "Silent Killer"
                  1948 HD FL "Thin Mint"
                  1978 FLH 80 "Grumpy"
                  1960 HD FLH Duo "Blue" (w/family in Sacramento)
                  1986 Honda CMX 450 (51hp rat sleeper) SOLD
                    • 9980
                    OH! You mean the bluing.
                    Can't have everything.
                    • spectra
                      • Aug 2017
                      • 113
                      • Vancouver, WA
                      A Few Questions.............
                      woops............wanted something else........
                      79 SF
                      • spectra
                        • Aug 2017
                        • 113
                        • Vancouver, WA
                        [QUOTE=Barbarosa;502764]
                        Why no center stand?
                        79 SF
                          • 8051
                          AFAIK, the Mac 4 into 1 is the only exhaust being manufactured for XS1100. (excluding Campbell X-pipe and stainless steel reproductions)
                          MAC Exhaust
                          Center stand retention is claimed, but I'm not convinced that's the case.
                          • MPittma100
                            • Aug 2011
                            • 2359
                            Used Special Exhaust
                            Used Special exhaust systems can be found for sale on occasion on EBay. One of those would allow reuse of the stand and would be original equipment. Also where a lot of sellers offer the Mac systems.
                            https://www.ebay.com/sch/i.html?_odk...haust&_sacat=0
                            1981 XS1100H Venturer
                            K&N Air Filter
                            ACCT
                            Custom Paint by Deitz
                            Geezer Rectifier/Regulator
                            Stebel Nautilus Horn
                            EBC Front Rotors
                            Limie Accent Moves On In 2015
                            Mike
                            • spectra
                              • Aug 2017
                              • 113
                              • Vancouver, WA
                              MAC Exhaust
                              Yes from MAC but here are plenty of people selling them in the aftermarket that have old stuff. I have found a few MAC exhausts on the web.
                              79 SF
