3k Stumble
  • spectra
    • Aug 2017
    • 113
    • Vancouver, WA
    #61
    Ok not sure WTF happened...........did the planets align..........should I go buy a lottery ticket.........hell maybe it was just the beer anyway played with this thing all day messing with wires and cleaning connections and greasing connections.......oh and also pulled the carbs off again and ran through them one more time.......getting good at it now.......bench sync and put it back together.......hooked up my 4 gauge vacuum set up to sync it and it fired right up a little adjusting on the idle and to be honest only carbs 1 and 2 needed a little tweak.......3 and 4 were good. Bike runs great and doesn't have any issues in the garage......will get it out tomorrow and see what happens not holding my breath
    79 SF
      Still holding........let us know. BA80's post #56 may be where this is headed.
        • 5062
        #63
        Ok not sure WTF happened....... Bike runs great and doesn't have any issues in the garage......will get it out tomorrow and see what happens not holding my breath
        Well, assuming you didn't convert the petcocks, if any of the float valves leaked while it was sitting, perhaps the carbs run better with higher levels. If you ran the bike a significant amount of time however, it would go back to the way it was. These bikes do like to be run! Maybe it just needed to "wake up."
        • spectra
          • Aug 2017
          • 113
          • Vancouver, WA
          #64
          Just woke up 6:30 here and will get it out in a few.
          As for the pilots they are the factory 42.5s and have not trimmed the wires ? Whats entailed in that one.
          Plugs were new.
          79 SF
          • spectra
            • Aug 2017
            • 113
            • Vancouver, WA
            #65
            Convert the petcocks? Octi has been removed by PO so all that I have is plugs on the prime side and lines running off the other side.
            79 SF
              • 8800
              If you unscrew the spark plug cap from the wire, you can trim off 1/4" and screw back on. This ensures a good fresh connection with no corrosion.
              • spectra
                • Aug 2017
                • 113
                • Vancouver, WA
                #67
                Ok got it out for a run around the block as I still don't feel comfortable getting it out on the street......has a stumble at about 2K but once past there it runs like a raped ape. Anything over 3K and its smooth as can be.
                Still has a little pop in the exhaust so there is still some tweaking to be done on the carbs.
                79 SF
                  • 9980
                  The cooler evening air may have cooled the pickup coils enough to drop the resistance down so the TCI could recognize the signal and fire the coils. Temperature affects the resistance in them.
                  I fought one a wile back that WOULD NOT START below 40 - 50 degrees. Those pick ups were reading LOW resistance. In the 650 ohm range. If I put a space heater next to the left engine cover and let it warm up, the resistance would increase and it would fire right up.
                  It almost took me on that short drive to crazy trying to figure that one out.
                  Swapped out the pick ups with some that ohmed out correctly and never had another issue.
                  • mschor
                    • Jan 2017
                    • 183
                    • West Palm Beach, FL.
                    #69
                    If you continue to have little hesitations here and there, replace the butterfly shaft seals in the carbs if you haven't already. That was the missing link to getting mine free and clear after much trial and tribulation
                    81 Special
                    • spectra
                      • Aug 2017
                      • 113
                      • Vancouver, WA
                      #70
                      Thanks I may just try that since there so old anyway. I am sure I will have the carbs off again soon.....
                      79 SF
                      • spectra
                        • Aug 2017
                        • 113
                        • Vancouver, WA
                        #71
                        Originally posted by BA80
                        That actually sounds a bit like a pilot circuit/ pilot jet issue. Incorrect style or aftermarket pilot jets will cause that.
                        I'm assuming your plugs are fresh and you've trimmed the plug wires and made certain they are getting good contact.
                        Ok this makes me wonder on the pilot jets.....how can one tell what brand of pilot jet? I am pretty sure they are the mikuni ones as I dug them out of a parts pile that came with the bike. One of the POs swapped jets like candy on this thing.......I have so many jets and extra carb parts its nuts I would like to just order some genuine mikuni stuff and be done with it but don't want to get the wrong stuff.
                        Factory was 137.5 main and 43.5 pilot but wondering if I should bump the pilot up one size ?
                        That seems a bit high, should be around 750.
                        Yes I checked again and one set was 750 and the other 755
                        Temps were hot that night to. I think the pick ups are good from what I have found so far.
                        Ok where can I find these at? Not even sure what sites to look at for parts for the XS ? I know of Mikes as I have some 400s but they are very limited.
                        Thanks everyone also for the help! I think that this is going to be an enjoyable adventure with this project. Almost through in the towel as I only paid 400 for it and bought maybe 150 in parts to get to this point. Time well we al know we cant keep track of that I think that is why I bought the thing I like to tinker on things........almost is therapy to me.......
                        Anyway have a few more questions and figured I would just keep them here. So I want to throw a little money at it as its a keeper. First off new coils as I did chop the plug wires to get to fresh and a couple are right there in length so......what do people recommend? Saw the Dynas and also accel
                        New shoes are on the way. I have used the Shinko brand before so just went with the 712s for a price point.
                        Also cables who recommends what brand and where ? I am going to be swapping on some other bars as I am just not a fan of the factory ones. I may need to shorten them up a little but I know the clutch cable needs replacing....
                        Looking at SS lines and probably just go to a local speed shop and have some custom ones made. Unless there is a better option out there ?
                        79 SF
                          • 9980
                          [QUOTE=spectra;502583]Ok this makes me wonder on the pilot jets.....how can one tell what brand of pilot jet? I am pretty sure they are the mikuni ones as I dug them out of a parts pile that came with the bike. One of the POs swapped jets like candy on this thing.......I have so many jets and extra carb parts its nuts I would like to just order some genuine mikuni stuff and be done with it but don't want to get the wrong stuff.
                          Factory was 137.5 main and 43.5 pilot but wondering if I should bump the pilot up one size ? [quote]
                          Look in this thread. Post #4 shows the genuine Mikuni markings. http://www.xs11.com/forum/showthread.php?t=44730
                          I can help you get the right stuff from Jets-R-Us if you want new. Pricey though.
