3k Stumble
The list changes. -
I tore the carbs down this morning to bare bones.......blew everything out with cleaner and air then re assembled and bench sync. Put them on and it runs like crap. I am leaning towards something other than carbs. How would it run great except for a little hesitation to not wanting to run at all. I cant even get it to run well now........79 SFComment
. A good start for this is remove leftside ignition cover, tugging on pick-up coil wires looking for wire insulation that stretches a bit indicating the fine little wires under insulation are broken......a known common issue resulting from mechanical advance rotation eventually weakening and breaking wires under insulation. Do DO this and report back findings
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
+1!.......carbs are possibly having electrical issues. A good start for this is remove leftside ignition cover, tugging on pick-up coil wires looking for wire insulation that stretches a bit indicating the fine little wires under insulation are broken......a known common issue resulting from mechanical advance rotation eventually weakening and breaking wires under insulation. Do DO this and report back findings
Update this thing has a mind of its own as now it run good againIdles great and rolls off idle decent with just a little backfire as I think its running lean now. Black on plugs is gone and now a little grey on there. I did replace the plugs as I had another set in the garage.
So question is if I re jet do I do both the mains and the pilots or ? this is all new to me............
Thanks!79 SFComment
Neither at this point. Just LOOKING at those pick-up coil wires is NOT correct method of inspecting them. You need to use both hands and tug every inch of those wires. The previous repair, if soldered and not crimped using a shortened butt connector then sliding the small piece of shrink tubing over it can be at fault. The heat from soldering those wires weakens the wire, and can break again next to repair. The suspect issues need to be solved BEFORE any re-jetting is even considered.....always, always.
If it ran like crap and now runs great with no concrete explanation as to why the change, then it sounds like you have an intermittent problem. My non-expert opinion is that it is most likely an electrical problem.
Personally, I would ignore the carbs and try to find the mechanism that is the root of the intermittent problem. Try to induce the problem by wiggling wires and connectors while the engine is running.
These bikes have 35+ year old wiring and 35+ year old interconnects, etc.82 XJ1100 - sold
2000 ZRX1100 - sold
2003 FJR1300 - Silver rocketComment
Hang in there, man you'll figure it out! I had a host of problems with one of my bikes, and eventually sorted it all out.
First, when you had the carbs apart, did you change the orings for the needle and seat, or at least check them along with that filter? If those orings are bad, which they were on both of my bikes, they'll leak fuel and things will never be right.
Next, really pull on those wires for the vacuum advance while the bike is running. I was chasing my tail, assuming I still had "carb problems" when I finally tugged on those and it killed the bike every time. I soldered them and took the bike for a run and was so happy it was all fixed....until it broke down on me.,..
That turned out to be a blocked vent inside the fuel cap. I took the fuel cap apart and the tiny little hole in the rubber grommet was plugged solid. I fixed that and my bike runs like an absolute champ. She just purrs at idle, and when I crack the throttle she is off like an animal possessed. Wish I wasn't so far north of you, I'd be happy to help you out.1980 XS1100G. Work in progress.
1980 XS1100G. 2nd work in progress.Comment
I did go over them feeling as I know what a messed up wire looks like. I have a few older XS models in he smaller size. I re wired one and thought of going that rout on this but decided against it.
Thanks! and yes wish you were closeranother set of eyes is always better.......
79 SFComment
Tell me more on what it was?
I tore the carbs down this morning to bare bones.......blew everything out with cleaner and air then re assembled and bench sync. Put them on and it runs like crap. I am leaning towards something other than carbs. How would it run great except for a little hesitation to not wanting to run at all. I cant even get it to run well now........Greg
The list changes.Comment
I am pretty sure they are ok. I poke prodded and pulled on all of them to no avail on having anything happen.
Was bored this afternoon so got to reading and pulled my meter out. Found an article on checking ohms at the ignition box so did that and everything checked out.....cleaned all the connections and new grease on there. Checked coils they panned out at 1.5 just like it says.....cleaned and greased all terminals.
Still going over posts trying to see if there is that little thing that I may have missed......bike runs but is still a little sluggish in the low end and spits a little.79 SFComment
That actually sounds a bit like a pilot circuit/ pilot jet issue. Incorrect style or aftermarket pilot jets will cause that.
I'm assuming your plugs are fresh and you've trimmed the plug wires and made certain they are getting good contact.Greg
Still going over posts trying to see if there is that little thing that I may have missed......bike runs but is still a little sluggish in the low end and spits a little.Greg
Will check again tonight.....its 100 plus in the garage and 75 in the housebike is in the garage........even with the fan blowing I said this is nuts it can wait.
If to high what would that indicate? I know very little when it comes to electrical stuff. Just enough to get myself in trouble.79 SFComment
