I decided to start my own thread on this particular issue for numerous reasons.
( 1 ) I studied the following link & cannot figure out how one can view the pictures that are shown.
LINK: http://www.xs11.com/forum/showthread...811#post363811
( 2 ) The original thread was a extension of another members post although it was the exact same issue.
LINK: http://www.xs11.com/forum/showthread.php?t=46761
( 3 ) I've decided to post pictures of my own, this may help clarify as well as describe with certainty of my particular situation.
So before I go further, is the reason I am unable to view the pictures due to broken links or is this the issue?
http://www.xs11.com/forum/showthread.php?t=35341
There is ALOT OF REALLY beneficial information within this site but some of it's a bit broken, not that it's a bad thing but I'm kinda lost on a few things but I'll get through it.
About My Bike
1982 Yamaha XJ1100 Maxim
I purchased this bike for $1100 cash & got a cheap helmet & a pair of riding gloves & a nice heavy riding leather jacket to boot! My intention from the start was to completely restore it from the ground up except for the motor which only has 12,542 original miles on it! The guy I bought it from laid it over while sitting still 3 times, that was his claim & you can see it from the pics that wasn't exactly true but for the money I didn't think it was too bad!
Pic: https://i.gyazo.com/65b91884dc3488db...6e41904cac.jpg
Here is what it looked like when I purchased it!
Pic: https://i.gyazo.com/0e6d7b083a94d1c9...a1776a5118.jpg
Pic: https://i.gyazo.com/39b80d5b96cf42c7...0b8dcdf316.jpg
Here's what it looks like as of now!
Pic: https://i.gyazo.com/f0a3e2ff0f16f9ab...ced84d1e45.jpg
Pic: https://i.gyazo.com/75176cdebbd3acb2...1773a342e1.png
Pic: https://i.gyazo.com/d35e62bd5ff5bb16...fb85a438f5.jpg
Pic: https://i.gyazo.com/d5b1557bae4268aa...a9e3523d88.png
Pic: https://i.gyazo.com/6da111ee271c237a...66df81b35b.jpg
Pic: https://i.gyazo.com/b0cc11fecd3c91b5...77e28eef8c.jpg
Pic: https://i.gyazo.com/ca7714c81ccb4db6...c1be77eace.png
I've replaced or reconditioned the following items on this bike, numerous new parts:
( 1 ) Complete Headlight assembly ( salvage )
( 2 ) Replaced the instrument cluster exterior shell ( salvage )
( 3 ) Handlebar grips ( new )
( 4 ) Mirrors ( salvaged )
( 5 ) Right front turn signal ( complete )( salvaged )
( 6 ) Both Clutch & Brake Levers ( new )
( 7 ) Front Fender ( salvaged )
( 8 ) Replaced front Brake pads ( new )
( 9 ) Replaced front wheel bearings & seals ( new )
( 10 ) Front Fork Oil ( new )
( 11 ) Clutch cable ( new )
( 12 ) Left side timing cover ( salvaged )
( 13 ) Right side alternator cover ( salvaged )
( 14 ) Timing Chain Tensioner ( new )
( 15 ) Fuel Lines ( new )
( 16 ) Petcock Kits ( new )
( 17 ) YICS fuel vacuum kit ( new )
( 18 ) Front & Rear Tires ( new Kendra's )
( 19 ) Alternator Brushes ( new )
( 20 ) Battery ( new )
( 21 ) Battery Box Top ( salvaged )
( 22 ) Signal Flasher ( new )
( 23 ) Pivot Shaft Cover boot w/spring clamps ( new )
( 24 ) Rear Brakes ( new )
( 25 ) Tool Kit ( salvaged )
( 26 ) Owners Manual ( salvaged )
( 27 ) Service Manual ( salvaged )
( 28 ) Exhaust COMPLETE ( salvaged stock )
( 29 ) Exhaust gaskets ( new )
( 30 ) Spark Plug Wire Ends ( new )
( 31 ) Spark Plugs ( new )
( 32 ) Engine Oil & filter ( new )
( 33 ) Final Drive Oil ( new )
( 34 ) Transmission Oil ( new )
( 35 ) Foreward Footpegs ( salvaged )
( 36 ) Luggage Rack ( Not Pictured ) ( salvaged )
( 37 ) Air Cleaner ( new )
( 38 ) Rear Turn Signals ( salvaged )
( 39 ) Lockhart Oil Cooler ( salvaged )
( 40 ) All new paint including the frame! ( Aztec Pearl Orange w/metallic flake )
( 42 ) Carb Kits or whatever it takes to fix them! ( new )
( 43 ) Rear Axel Wheel Bearings ( new )
( 44 ) Rear Axel Seals ( new )
( 45 ) Brake Fluid ( flushed / new )
( 46 ) Parts Catalog ( new )
As you can see I have hours & money invested into this bike thus far & yes it runs PERFECTLY other than the carbs flooding the air box. I also intend to clean the fuel tank while I have it removed, it's not that bad but I want it better than it's current state. I'll post more as I go thru the process of fixing the carbs but that's it for now.
If I need to use a different format just let me know & if size matters I will adjust that as well.
About My Bike
