80 SG keeps blowing the turn signal (30amp) fuse....
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    I have no idea why all of a sudden. One common denominator: It was wet out when it started happening. I have a blade type fuse holder!
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
    30 amp is not your turn signal fuse, is it? The main fuse is 30 amp.
    • ERM83
      • Apr 2016
      • 314
      • Lehigh Valley, PA
      yep...didn't mean to hit the "3" key. regardless, it's blowing them out...all my connections look fine....
      79' SF carbs
      MAC 4-1
      K&N Pods
      Accel 3.0 coils
      Tarozzi fork brace
      TC fusebox
      Picture update soon
        Bulbs are correct? I would check for a wire with worn insulation between the fuse and the bulbs. Check the feed-through at the stalks near the fender and at the front end.
        • ERM83
          • Apr 2016
          • 314
          • Lehigh Valley, PA
          I'm gonna check that now. I'm on my 5th try figuring it out / fuse at the moment. Just got back from a ride, and blew two of them..despite my efforts. I cleaned the HELL out of EVERYTHING. i'm (ONCE AGAIN) IRATE with this thing. Expletives galore at my apartment.
          79' SF carbs
          MAC 4-1
          K&N Pods
          Accel 3.0 coils
          Tarozzi fork brace
          TC fusebox
          Picture update soon
          • ERM83
            • Apr 2016
            • 314
            • Lehigh Valley, PA
            One thing I should mention: it will just blow out while riding. I'll use my signal, turn it off, then the next time i try to use it, NOTHING.
            WHY. I HATE ELECTRICAL PROBLEMS.
            79' SF carbs
            MAC 4-1
            K&N Pods
            Accel 3.0 coils
            Tarozzi fork brace
            TC fusebox
            Picture update soon
              Have you checked the switch itself for loose wires?
              The solder work sometimes wasn't the greatest and the switch is old. Be very careful when you open the switch or if there weren't any loose wires when you opened it there will be before you close it.
              • ERM83
                • Apr 2016
                • 314
                • Lehigh Valley, PA
                I also just put in a mike's xs signal assembly. wired it up correctly, and everything about a month ago. I THINK it may be the crimp in the right turn signal wire to the actual light...that makes the most sense. put a whole new assembly on, and it was FINE until the wet roads. will report back!
                79' SF carbs
                MAC 4-1
                K&N Pods
                Accel 3.0 coils
                Tarozzi fork brace
                TC fusebox
                Picture update soon
                • ERM83
                  • Apr 2016
                  • 314
                  • Lehigh Valley, PA
                  well, just cleaned up the rear turn signal wire...still blows out after...about a minute and a half of riding. By the way, it'll just blow when i'm riding...not even using the signal. I can feel it. the bike just slows down, and then it doesn't work. I cannot figure this out for the life of me.
                  79' SF carbs
                  MAC 4-1
                  K&N Pods
                  Accel 3.0 coils
                  Tarozzi fork brace
                  TC fusebox
                  Picture update soon
                    You need to check the function of the voltage regulator at say 3500 rpms. It could be allowing overvoltage and over amping. ALTHOUGH I can't see it blowing the turn signal circuit without using the turn signals.
                    • ERM83
                      • Apr 2016
                      • 314
                      • Lehigh Valley, PA
                      would the relay do this??? may be a stupid question...I just don't know my s*$% when it comes to the electrical aspects of these things...
                      79' SF carbs
                      MAC 4-1
                      K&N Pods
                      Accel 3.0 coils
                      Tarozzi fork brace
                      TC fusebox
                      Picture update soon
                        It's probably not the relay. The SIG fuse is 20A because it's a catch-all circuit. If it's noticeable when it pops during a ride, that's a pretty decent short.
                        Let me find a schematic or several... alrighty then!
                        Flasher Relay
                        Flasher Self-Canceler
                        Self-Canceler reed switch in the Speedometer
                        Turn Signal Switch -- Brown/White wire from the Flasher
                        Turn Signal Lamps -- Dark Green or Chocolate wire from the signal switch
                        Turn Signal Indicator and the diodes for the Special -- Dark Green or Chocolate wire from the switch
                        Horn(s)
                        Fuel Light/Gauge
                        Neutral light and switch
                        Oil light and switch ('79 Special has the Brake Lamp Monitor circuit too)
                        2-pole Brown wire spade connector in the headlight shell:
                        Brake light switch (front and rear switches)
                        Switched and Fused Accessory Power -- normally not connected to anything
                          And the Tachometer. Almost forgot.
                          • MPittma100
                            • Aug 2011
                            • 2359
                            Automatic Breaker
                            A great way to remove frustration when hunting a short circuit is to use an automatic reset breaker in place of the fuse as a tool. Can be had in 10-30 amp ratings. When the short occurs, breaker trips. When it cools down, it resets. Hunt for the short while the tripping occurs. When found, reinstall the correct fuse.
                            Buy them in any parts store.
                            1981 XS1100H Venturer
                            K&N Air Filter
                            ACCT
                            Custom Paint by Deitz
                            Geezer Rectifier/Regulator
                            Stebel Nautilus Horn
                            EBC Front Rotors
                            Limie Accent Moves On In 2015
                            Mike
                            • ERM83
                              • Apr 2016
                              • 314
                              • Lehigh Valley, PA
                              here's the thing...
                              I had ZERO problems with any fuses blowing until recently. the fuse i'm posting about blew once in traffic...but that was it. nothing like that happened for MONTHS. then, once again, I ride home from work when it's wet out...a NEW problem. I'm going to look into the instrument cluster, because it DEFINITELY isn't the reg / rec...switched that out, and it STILL blew within 3 minutes of riding. SOOOOO PISSED RIGHT NOW....
                              79' SF carbs
                              MAC 4-1
                              K&N Pods
                              Accel 3.0 coils
                              Tarozzi fork brace
                              TC fusebox
                              Picture update soon
