"Follow The Yellow Brick Road!"
The Cracks.
I split the case to fix the transmission, replace the cam chain, and do a general inspection while the engine's out of the frame.
Charlie the 3rd Shift Wonder Chimp strikes again.
Oh, no! The number two connecting rod bearing has a problem.
The number two connecting rod journal is marked up too.
I have a full set of new Blue rod and main bearings ready to drop in so it's not as bad as it looks.
This is why I split the case instead of crawling under the engine again and getting a faceful of oil to fix the transmission.
Gratuitous garage picture.
The Cracks.
. That one rod journel looks a bit metal spun, but shouldn't be an issue as long as you don't pass by 'you know where' in Utah!
