Deleting the TCI
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    Originally posted by TheNeverCat
    Anyone have a good quality picture of this?
    i need one... for science.
    Sorry, no longer have it
    • CaptonZap
      • Jun 2010
      • 1748
      • Denver
      Here are some sites that may provide you with some useful information. They are not for the 81's, but the color codes were probably close or the same.
      I would also suggest that you beg, borrow, or steal a Clymers Manual # 411, which has a wiring diagram for the XS1100H, (1981) on the back pages. They are not in color, but you should be able to decipher the colors from the position of the wires, or by referencing the colors in the third site listed.
      And a tip o the Hatlo hat to 3Phase;
      https://lh3.googleusercontent.com/-4...2/XS11G_US.jpg
      http://dave_jack.tripod.com/id41.htm Maybe it will work
      • Prothec
        • Jul 2007
        • 587
        • Fort Myers, FL
        Found the larger image in my stash of documents:
        Website/Blog
          NeverCat, I suggest sending 3Phase(Scott) a PM. He has and would likely be able to scan and PM you the complete wiring diagrahm....in COLOR.
            I don't have any schematics for the '81 Standard or Special but T.C. stashed some color copies here on the site in the Links forum:-
            XS11.com Forums > Idle Talk Forum > Links > Colored Wiring Diagrams
            • TheNeverCat
              • Dec 2016
              • 46
              • East Point, GA.
              You folks are THE BEST!
              I brought the bike home and I've decided to just move the TCI and wire in the M-unit to that.
              With the spare TCI I'm going to see if there are any more stable components I can upgrade inside of it (as it seems to be a common point of failure)
              I think I'll move the thread to my introductory thread just to keep the clutter down as from here forward unless I discover anything new I'll be updating my work there.
              Awesome how we got a lot of scattered info in one place now
              MUCH APPRECIATED
              1980 SH - 100% custom wired Road warrior with motogadget everything.
              Looks like a scrap heap, runs like a dream.
              Master of the wires.
                NeverCat, the TCI is NOT a common issue. The only occasional issue I've seen on here is for whatever reason, internally, they have developed a 'cold' solder connection which can easily be rectified by re-soldering that connection.
                  • 7819
                  +1 on that. The other issue is running 1.5 Ohm coils, as that WILL burn out the transistors. As yours is a 1981, it came with 3 Ohm coils, so any 3 Ohm replacement will work with no problems.
