damnable carburetors just wont go away
  • puskrat
    • Jun 2015
    • 312
    • Peoria IL
    Originally posted by dbbrian
    Are you aware that the screws that are on these bike that aprear to be Phillips are not?
    They are JIS (Japanese Industrial Standard) which is slightly different than phillips. A phillips screwdriver will mess up the JIS screws every time.
    You need to get JIS screwdrivers to work on theses bikes.
    http://www.vesseltools.com/hand-tool...-products.html
    I am. I do not have JIS bits but have sourced ordered some.
    "Venturered" 80 XS1100G - "DoraMax" getting sort of resto/destro ed.
    Yeah it's a pretty blue, but just because you're old is no excuse to buy a bagger. Fortunately I have wrenches.
    • puskrat
      • Jun 2015
      • 312
      • Peoria IL
      The carbs are gone away (as a problem). back on the bike, with XS pods, all the screws replaced (albeit with some at extra length). One of the carb boot clamps was destroyed when I took them off, so I ordered two replacements. I do not know why two.
      • dbeardslee
        • 4385
        • Maineville, OH
        With Mikes XS pods the hose clamps are usually a little too wide. Makes 'em want to slip off before they get all the way tight. I robbed Betsy's old airbox for its thinner clamps, and they work a LOT better. JAT
          Probably. you see, every allen head Ive used has stripped out. Or the socket rusted after the finish failed. Those weren't stainless
          Well.......with that style of fastener, can easily see that happening when you try to "strong-arm" the fastener.
            • 7830
            I find almost every stainless bolt and screw I need at my local Ace Hardware. I use the button heads for a lot of things, as they look nice, and aren't as high as the standard allen head.
            • puskrat
              • Jun 2015
              • 312
              • Peoria IL
              Thanks Beard! NOW I know why I ordered more band clamps than I needed. I had noticed the "squeezing off" problem with the pods but didn't connect it to the clamp size. God is good.
              ETA... turns out the ordering two thing was only part of the overabundance. As I still haven't disposed of any take-offs, I have clamps from the airbox also. Happy Happy
              • dbeardslee
                • 4385
                • Maineville, OH
                God is good.
                Yes He is. But He's got a sense of humor too, so tread carefully.
