'79 XS project by a mechanical newbie. (But hey, it was free)
  • stoneairsoft
    • Sep 2016
    • 94
    • Minnesota
    #136
    Let me see if I can get this right: (Many of the clearances are right on the border of which pad to install, and most of you are saying go with the bigger clearance, in which case, I'd need a 280, a 275 and a bunch of 270s instead)
    Intake:
    #1 - 290: clearance .10mm NEED 280 have one
    #2 - 285: clearance .06mm NEED 275 (couldn't read stamp on actual shim...borrowed a 285 from the exhaust to measure)
    #3 - 285: clearance .10mm NEED 275
    #4 - 280: clearance .14mm NEED 275
    Exhaust:
    #1 - 285: clearance .15mm NEED 275
    #2 - 285: clearance .20mm NEED 275
    #3 - 290: clearance .20mm NEED 285 have one
    #4 - 290: clearance .18mm NEED 285 have one
    Anyone have a bunch of 275s they'd be willing to sell?
    I'm using the conversion chart on pages 2-6 and 2-7 of the Yamaha manual. http://ringler.us/xs1100/XS1100H-SH-...ice_Manual.pdf
    '79 XS11 Special with '80 carbs
      • 735
      shims
      I have a couple 275's a couple 270's . I'd trade for any smaller sizes than that if you have them. But I already have too many 290's, 295's and 300's.
        • 735
        I'm going to shim my LH tomorrow or the next day, I'll see what I have left over and pm you. I should be able to help you out with at least a couple of the ones you need.
          • 7828
          Just checked my box. Sorry but I only have 1 270. Everything else is 260 down or 285 up.
          • stoneairsoft
            • Sep 2016
            • 94
            • Minnesota
            #140
            Unfortunately, I don't have any spares with which to trade, so I would need to buy them straight up. (unless you need the big boys for a brand new bike)
            Do my new shims seem accurate based on the old ones and the measurements?
            Would Andreas have some? I'll PM him.
              #141
              I think Kawasaki had models with similar diameter shims if you are having trouble finding them. Take a shim with you to compare diameters...
                • 8920
                You need the 29mm shims for our bikes, here is a source for them...
                Valve Shims for Bikes in CRC2's Online Catalog of New motorcycle Parts and Accessories Indy
                  Correct Sid, Kawasaki uses same diameter shim.
                    #144
                    Cheap valve compressor tool.
                    This is something I just found, although it comes late for you!
                    • stoneairsoft
                      • Sep 2016
                      • 94
                      • Minnesota
                      #145
                      I checked with the local shop for shims and they want $8 a piece for them. With needing 5 shims, $40 seems a bit ridiculous as that's half a shim kit. I'm hoping someone can hook me up on here for a bit less.
                        • 735
                        I have two 275's that I can send you, no charge, If you want to send me a couple of whatever sizes you have left over, that's cool. if not no problem, just pay it forward someday. Hopefully someone else here can help you out with a couple of more. PM me with your address.
                        I've been trading shims with some other folks too and was thinking about setting up a shim exchange system of some sort but I'm not sure how that would work out, i think it has been attempted by a few others.
                        • Bergman16
                          • Jun 2014
                          • 286
                          • New York, N.Y.
                          #147
                          I can send you one, hopefully you can get your hands on two more. PM me.
                          Steve R
                          '80 SG
                          Former bikes:
                          1978 XS400E Red
                          1981 XS850 Special (Stingo)
                          • stoneairsoft
                            • Sep 2016
                            • 94
                            • Minnesota
                            #148
                            Thanks gents!
                            I PM'd both of you. I could probably use 270s for a couple of those gaps as well. Most of my measurements are on the borders of their ranges.
                            Just two more! I have the gaskets ready to go and just need these to finish up the valves before reassembling and praying for my dear life. Got my first kid coming soon so I won't have time to mess with it after that. It's now or...literally, never.
                            • Bergman16
                              • Jun 2014
                              • 286
                              • New York, N.Y.
                              #149
                              One 275 in the mail. Rooting for you
                              Thanks gents!
                              Steve R
                              '80 SG
                              Former bikes:
                              1978 XS400E Red
                                • 7828
                                I can send the 270 I've got. send a pm with address.
