I have these set at 25 right now and they still leak and the bike is hard to start with the fuel level that low.
1980 carb float setting
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.โ
โ Albert Einstein
The list changes. -
Well
for me it didn't matter what I set the levels at, they eventually exceeded the tolerance of the needle. I used the clear hose method to originally set the levels then left the gas on and watched over a period of time. Eventually they all failed. When you get a good set of fuel valves and needles they will shut off the fuel with the tangs with almost no adjustment. The more you have to distort the tang the less likely the viton tips will hit the same socket profile.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
