1980 carb float setting
    What do y'all se your G and SG floats at? The book says 23mm but that's way too high, I have them set at 24mm now but it still floods when sitting with the engine off and it loads up at stop lights.
    Gonna try 25mm next.
    • 2097
    23mm
    I set my '80G at 23mm and the following pic is where my running fuel levels are:
    But I'm still dialin' her in and not sure if I'm too lean. I may raise the level a mm before I change any stock jetting.
      • 734
      I set my LG at 23 and it seems to be fine.
        Pretty sure I have some leaky float valves. I got them set at 25mm now and it's still doing it. And yes, I did replace the O-rings on the valve seats.
        There is one float with some damage also that may be causing a problem.
          Joe, next time, turn them right-side-up and blow into the fuel supply hoses. If they are sealing, you will probably know it.
          Other things are,
          1. Leaking seals/o rings for specials at the fuel valve in the carbs,
          2. Blocked breather lines for older carbs, Note: you can't use a newer air box with older carbs and hook up vent hoses to the air box nipples.
          3. Floats not able to function correctly due to contact with gasket or other,
          4. Crusty float pivot action,
          5. Debris on fuel valve or other reason for seal failure,
          6. Pin of fuel valve needle is sticking (leaking valve).
            Other things are,
            LOL.....I ain't Joe.
            I cleaned these carbs quite well and replaced the o rings as I said. Everything mentioned has been checked. Using old parts though.
            • HalfCentury
              • 408
              • Burlington NC
              Flooding sounds like the seat/needle seal is leaking. You know more about this than lots of people. Did you replace all the soft parts?
              82 XJ1100 - sold
              2000 ZRX1100 - sold
              2003 FJR1300 - Silver rocket
                Old valves. See post #6
                • MPittma100
                  • Aug 2011
                  • 2359
                  Float setting
                  Hi Greg AKA Joe,
                  I've had the best results with the highest float setting. I've also found, when using the tubes for checking, that it verifies the need for the highest setting. The last Venturer carbs I did needed a little more than spec to get proper tube level. And it does appear that some new float valves are needed.
                  YOU COMING TO XSSE?
                  1981 XS1100H Venturer
                  K&N Air Filter
                  ACCT
                  Custom Paint by Deitz
                  Geezer Rectifier/Regulator
                  Stebel Nautilus Horn
                  EBC Front Rotors
                  Limie Accent Moves On In 2015
                  Mike
                  • RichW1064
                    • Aug 2016
                    • 79
                    • Hardy Dam, MI.
                    isn't there a carburetor-less float solution..? seems to me, oh several years back I recall hearing about the "electron carb"... am I the only one to hear of this thing? had one on a old 85 dirt bike, worked well, but cant seem to find them anywhere... was I dreaming or in a state of wishington..?
                    79_xs1100special
                      Sorry Greg! ...and Joe.
                        YOU COMING TO XSSE?
                        Not looking good Mike. I got the time off work but other factors are not working out.
                        • MPittma100
                          • Aug 2011
                          • 2359
                          Xsse
                          I'm sure you will continue to try. Good luck. Hope it works out for you. Charlie Haas, Bohn Frazer, and maybe Karla Jones (The Jones Gang) are going to attend.
                          K&N Air Filter
                          ACCT
                          EBC Front Rotors
                          Mike
                          • mack
                            • 2411
                            • Ontario, Canada
                            I feel for you man. I've had some that just will not hold. I had set of LG carbs I was going to sell to Dwayne Potter but I couldn't get them to stop leaking. The inlet valves would hold for a few hours then randomly leak over night. Drove me crazy because it wasn't the same one that would leak at any given time. I've been working with Mike at Jets R Us to determine what the real numbers for genuine mikuni carb are. We have determined that their charts are incorrect and that while the site says "genuine mikuni" they are in fact mostly packaged by K&L. As a side note K&L IS just a packaging company not a brand name so they buy in bulk at the cheapest price ans what you get may be from china, Pakistan, Chec republic or mexico. You'll find that the needle heights can change dramatically:
                            For the 1980/81 carbs the only one that would seat and seal properly is the 18-4676 but it may come without the mikuni stamp and in fact be a K&L imposter ($8.99 makes me suspicious because you look at all the other mikuni seats and they are three times that price) and not seal. So the 007-503 number is actually a threaded seat. My advice is to state quite firmly that you only want 18-4676 that are in fact genuine mikuni with the stamp! The other issue is that mike won't have any in until mid September so I'm waiting for twelve myself.
                            mack
                            79 XS 1100 SF Special
                            HERMES
                            original owner
                            81 XS 1100 LH MNS
                            SPICA
                            78 XS 11E
                            IOTA
                            https://youtu.be/wB5Jfbp6SUc
                            https://youtu.be/RaI3WYHSuWA
                            Frankford, Ont, Canada
                            613-398-6186
                            • mack
                              • 2411
                              • Ontario, Canada
                              don't be put off that the pictures show metal needles, it just happens that it was the only picure I had handy on photo bucket. It's the same issue with the viton tips. I had some of mine at 27mm with the tang almost bent straight down and they still wouldn't seal properly for long.
                              mack
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              613-398-6186
