Diaphram leaking.
  • dbmb0416
    • Jun 2015
    • 128
    • Westdale Ny
    Diaphram leaking.
    Can anyone tell me where I can order new one. Got home from a ride to town and smelled gas. When I turn petcocks on fuel comes out backside facing front tire. Thanks in advance.
    79 XS11SF
    eBay, Seller GeorgeFix:
    • dbmb0416
      • Jun 2015
      • 128
      • Westdale Ny
      I was hoping for entire unit. Kinda like plug and play. . With my luck lately with vehicles none are left. Thanks for the link.
      79 XS11SF
      • dbmb0416
        • Jun 2015
        • 128
        • Westdale Ny
        TopCat this is the one also to fix the one where the Octopus plugs in. As that's where it was leaking?. I wasn't in my right mind last night when I came home from the ride and it was leaking.
        79 XS11SF
        • Rickrod3
          • Jun 2009
          • 721
          • Oakland, New Jersey
          By plug in play do you mean the whole petcock?
          I recently converted to an on off without the vacuum. Pricey but in my opion worth it.
          650SF
          XS1100SG Project bike
          • Prisoner6
            • Aug 2013
            • 1184
            • Phoenix, AZ
            Hi, David -
            The kit that TC posted has everything you need to repair 2 leaking petcocks and a leaking Octopus on your Special.
            Marco
            1979 Honda CBX
            2002 Kawasaki ZRX1200R
            WE MISS YOU, DON
              • 8800
              New octy...
              http://www.partzilla.com/parts/detai...520-01-00.html
              • dbmb0416
                • Jun 2015
                • 128
                • Westdale Ny
                That fit a 79?
                79 XS11SF
                • Prisoner6
                  • Aug 2013
                  • 1184
                  • Phoenix, AZ
                  That fit a 79?
                  Yes, it will ...
                  Marco
                  1979 Honda CBX
                  WE MISS YOU, DON
                    • 8800
                    Yes it will fit, 79-82 all the same. The 79 Special is no longer listed on any of the parts fiches, as if it never existed.
                    • dbmb0416
                      • Jun 2015
                      • 128
                      • Westdale Ny
                      Thanks guys. It had a pretty big hole in top. Part expensive but I shouldn't have to replace again. Again Thank You so much.
                      79 XS11SF
                      • dbmb0416
                        • Jun 2015
                        • 128
                        • Westdale Ny
                        Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
                        Wonder why I need a new one.
                        79 XS11SF
                        • CatatonicBug
                          • 6117
                          • Clinton, UT
                          In case you were concerned about it, that notch is supposed to be there, it's a vent. The leak would be an internal one.
                          • dbmb0416
                            • Jun 2015
                            • 128
                            • Westdale Ny
                            Yes I would. Especially when I get new part in and see it there too. Any knowledge I learn from you guys the better I am. Thanks.
                            79 XS11SF
                              • 8800
                              When you install your new unit, check to see if it is pulsing with the engine vacuum pulses. It can destroy itself prematurely if pulsing, but adding a restrictor in the vacuum line will eliminate this. I have had this problem with the Pingel aftermarket vacuum fuel valve, I think it could also happen with the OEM.
