Mad Maxine restoration
  • XJBlank
    • May 2016
    • 8
    • Vernal, UT.
    Hi folks, I'm new to posting on this site, but I'd like to share some of my experiences with my xj1100 "Mad Maxine" project bike. My dad purchased it when I was in high school knowing it had the notorious 2nd gear issue. My older brother attempted to diagnose the problem with no luck and left a pile of parts and bolts when he abandoned it. A few years later, after I graduated, I decided to take on the issue myself and attempt a top end rebuild. I bought a manual and started reading this forum for ideas. I quickly learned that this was no small task. Back then, I had never worked on a four stroke, so this was my learning experience. I was also still an impatient teenager so I made lots of mistakes throughout the original project. I must have tore into the engine at least 5 times in order to finally get a running specimen over a 7 month period. Once I got it on three road for the first time I experienced the comfort of the low set seat along with the white knuckle thrust running through the shaft. It was the greatest 7 miles on a road bike that I had experienced up to that point. It was then, at 7 miles, that a valve dropped into the number 4 cylinder and got hammer into the head by the piston. All of that time and money I had put into it felt like a waist! I parked the bike and moved on to other bikes and interests.
    Fast forward 9 years to last year. At this point, I was now out of college and in a house with room to work. I decided to resurrect my juvenile passion and attempt to revive Maxine from her fallen state. I ordered a new top end, (head, cylinder, and piston) and took my time to rebuild it properly. I followed every step in the manual from pistons to valves to timing and even added some black engine paint to the top end for a clean look. I also meticulously wend through the carbs to ensure that every orifice was clean and clear. After assembly I learned that I had no spark. I spent hours sorting through the wiring diagrams to chase down the electrical gremlins that had snuck in over the 9 years of sitting. I finally found a broken wire near the shifter going into the left side case. I soldered it back together and punched the start button. The moment I had been waiting 9 years for had arrived as I experienced the low roar of the big in line 4. After some tuning. I had a decent running bike, accept for an occasional skipping first gear. I put about 200 miles on it with short rides around town. The ride was just as I remembered it 9 years earlier, smooth, comfortable, and fast! I got an opportunity one Saturday night last September to go for a ride with a buddy. We made it about 15 miles down the highway when I all of the sudden hear a loud knocking followed quickly by the engine locking up. I rolled to a stop and my buddy told me I had dumped oil all over the road. When we got it back to my place, I noticed a 2" Dia hole in the front of the case.
    Again, I parked it until it warmed up enough for me to really look into it. I started into it this April after I found a replacement case with crank on ebay for a good price. After I removed the engine and tore it down, I discovered that the connecting rod on #3 and come unbolted. The results were the crank slapping the connecting rod through the front and back of the case also breaking chunks out of the sleeve and piston. All in all, not too bad.
    I then proceeded with the task of transferring everything over to the new case. In the process, I also decided to perform the DreMel fix to my skipping gears. Since i had the old set of cylinders from 10 years ago lying around, i also took the good sleeves out to replace my broken one with. The BBQ grill made quick work of that! After a few weeks of work on it between career and family, I am almost ready to install the motor back in the bike. I have painted the case black to match the top end and polished the covers to give the two-tone look. I will post pictures as soon as I find out how! I still need to install the top end, but I'm not sure if I should do it inside or out of the frame. Any suggestions? Long story short, I'm excited for round 3 on this beast, and I hope that are no more catastrophic failures!
    82 XJ1100 "Maxine"
  • Bikes
    • Oct 2014
    • 174
    • Coastal Maine
    Wow...welcome.....talk about not giving up.....pretty sure I would have parted it out and moved on long ago but I gotta hand it to you...now you know the bike inside out....hopefully you will enjoy riding her for a long time.....
    Alhough I've not had the opportunity to rebuild an XS motor, I would think putting it together then installing it would be the way to go....
    Mark
    1980 xs1100g 3H5.......
    1992 Ducati 907ie
    2001 Moto Guzzi Jackal
    • mack
      • 2411
      • Ontario, Canada
      Con rods
      Your not the first guy to throw a rod and total the cases. I'm sure Crazy Steve will chime in but there is a specific way to torque the bolts and some times the bolt will stretch. The manual says to always use new ones but I couldn't find any either. The upper and lower cases should be bought as a matched set to ensure the journals and other surfaces mate properly. You've put a lot of work into it so far and many would have just scrapped it long ago. Well done!
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • XJBlank
        • May 2016
        • 8
        • Vernal, UT.
        Here is the before with my broken case:
        Here is the after with the new case painted.
        82 XJ1100 "Maxine"
        • XJBlank
          • May 2016
          • 8
          • Vernal, UT.
          If that didn't work, Here is a blog I started for the bike and all of the repairs I have and will do from here on out:
          82 XJ1100 "Maxine"
          • tcoop
            • Nov 2009
            • 793
            • South Weber, UT
            You definitely have patience. When my 78E ate a valve and put a hole in piston #3 and the case, I just found a different engine to put in it. I may be in you area on the 14th, it just depends on the route we take to get to the Colorado rally.
            Hope fully this time is the charm for you.
            Ty
            78 XS1100E - Now in Minnesota
            80 XS1100LG - The Punisher
            82 XJ1100 - Daughter's Bike
            • XJBlank
              • May 2016
              • 8
              • Vernal, UT.
              Tcoop, you're welcome to stop by on your way through! You can email me if you decide to. My address is jrblackangel73@gmail.com
              I would love to attend a rally some time, but I don't think I'll be ready this year.
              82 XJ1100 "Maxine"
              • jwhughes3
                • 2798
                • Home of the Alamo
                Congrats and welcome!
                You have the patience of Job. I had a similar instance of dropping a cap and totaled the engine in favor of a replacement. But I am less mechanically inclined it seems.
                You are already hooked from the first 7 miles and are a lifer. Its a unique bike and gets into your blood.
                I look forward to meeting you and your bike. We get to Utah sometimes and will be in Colorado next week.
                John
                '81 XS1100H - "Enterprise"
                • XJBlank
                  • May 2016
                  • 8
                  • Vernal, UT.
                  Here's an update on the project.
                  82 XJ1100 "Maxine"
                  • XJBlank
                    • May 2016
                    • 8
                    • Vernal, UT.
                    Bad link, This should be the correct link for the blog that shows the project updates:
                    82 XJ1100 "Maxine"
                      Nice work!
                      The only possible problem is where you used the taper at the bottom of the jugs to slip them over the pistons and rings.
                      Sometimes that works so you don't need to use the ring compressors with blocks for the pistons and you sing and dance a little hornpipe, sometimes you snap a ring and you sing and dance an entirely different tune.
                      Still nice work! Where... did you find a lavender seat?
                      • XJBlank
                        • May 2016
                        • 8
                        • Vernal, UT.
                        The bike was originally maroon when I got it and who've had it before me had the seat covered with a cover that is grey leather on the sides and maroon tinted upholstery on the top. It's great on a hot day, but ultimately doesn't match my black theme. I am looking for a black seat cover to match the theme. Do you have any suggestions on where to get a good seat cover?
                        82 XJ1100 "Maxine"
                          Back to black? That's a bummer, it looks like it matches someone's jumper and that kind of stuff's important!
                          For seat covers I've bought two from B and H Specialties in Hurst, TX aka
                          www.motorcycleseatcovers.com | XJ1100 Maxim
                          • XJBlank
                            • May 2016
                            • 8
                            • Vernal, UT.
                            Thanks! I love that cover with the bead on the edges, it looks awesome!
                            82 XJ1100 "Maxine"
                              • 5058
                              Looks great!
