Neutral switch
  • mack
    • 2411
    • Ontario, Canada
    Neutral switch
    Had a weird drip under the E, it was mostly on the left side but changed location. When it was finally time to drain the break in oil I actually got underneath the bike to see if I could find the source. Turns out the neutral switch was leaking. Not around the threads but through the switch itself. The oil would blow back on the frame and drip where ever it liked. I didn't know the switch could leak like that but as usual, if it could happen, it would happen to me. Luckily I had a spare so all is good now.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    I didn't know that it made physical contact with oil. I thought it was just an electrical switch...
    • MarkD
      • Jun 2013
      • 488
      • N. Michigan
      I don't think there's oil in the neutral switch part of the engine-- I replaced mine 2 years ago, and it was a no-leak change out.
      79 F
      1967 Suzuki X6 Hustler
      1973 Suzuki TM 125
      1979 XS1100 F
      2005 Kaw. Vulcan VN800
      1991 BMW K75
      • mack
        • 2411
        • Ontario, Canada
        I'm going to
        take mine apart but oil was leaking past the plunger and dripping out around the black mastic gasket around the screw seat. Then it dripped off the wire connector screw. Skids, oil is all over the place in that location, if the switch is faulty, the oil can get in.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
          Hey Mack,
          Glad you had a spare. BTW, research shows that the OEM # 2H7-82540-00-00 has be superceded by this one, used in both boat engines, and ATVs, as well as several V-stars. 4KM-82540-00-00
          boats.net has them for only $18.18 plus S&H.
          http://www.boats.net/parts/detail/ya...540-00-00.html
          I checked the microfiche, but I can't see the engine/tranny case area where the neutral switch scews into the engine, but it does make contact with a lever that pushes against it when in the neutral position, so I would expect there to be oil there.
          BTW, here's a photo from the Tranny repairs section explaining how the tranny works, and you can see beyond the tranny case cover in the upper right corner the neutral switch screwed into the case as the END position of the shift drum. Where is screws in is an oil chamber, but when the engine is stopped, all of the oil should be down in the sump pan, so it may have been able to be removed without loosing any oil.
          • mack
            • 2411
            • Ontario, Canada
            Oil Pan
            nice picture. The pan has deflectors that direct oil up into the shift drum when the gears turn. It's basically an oil storm in there with the motor running. The smaller deflector channels the oil rain to the kick start gear. It's such a simple efficient system. Thanx for the tip on a replacement. I priced one out up here and if I remember it was $38.00 can
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
              • 8893
              Edit.......
                • 8893
                You can put a short bolt in it"s place if need be with a brake hose crush washer, no more safety light though. The light will remain off with no ground feed.
                • mack
                  • 2411
                  • Ontario, Canada
                  thanx phil
                  good to know.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                    Hey Mack,
                    That is a perfect explanation TC, as always. Yo da' man!
                      But then I wouldn't be able to start the bike without holding in the clutch lever. I know not all of the bike have this interlock, but some do - like the added sidestand interlock on the XJ.
                        • 7818
                        Bug, ANYTHING can be bypassed. Just look at some of the "hold my beer and watch this" video's
                          True, but I hate it when people hack stuff like that just to bypass something that could be repaired.
                            • 7818
                            I understand! But the bolt/crush washer MAY get you home if the neutral switch breaks on the road. The rest was just a joke, as the "hold my beer" says it all....
                              • 8893
                              Edit: This modification may not work on 81 Midnight Special or 82 XJ1100 as there may be a safety interlock preventing the engine from starting.
