JeffH Bike Repairs - Colorado Rally Prep!
    • 6765
    Awesome job Kurt...Jeff...this bike has come a long way since the wired headlamp days...yep shes' a keeper...
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
      • 1261
      • Peachtree City, Georgia.
      Making progress.... Bags going on....
      XS Friends,
      Finished the painting yesterday. Not 100% happy but time is running short. I believe the paint mixer at PPG got the color close but it seems a little too RED.
      The Special emblems are not a perfect fit but much better than the crusty originals.....
      Still a ton of work to accomplish and only a few days left before Jeff gets her back.....
      KURT
      1982 - CBX1000 - Honda
        • 6765
        hard for me to find any faults...looks absolutely awesome...
          • 3352
          Can't wait to see the bike in person, in Colorado!
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
          • XJOK2PLAY
            • 2099
            • Skiatook, Ok.
            Way ta go, Kurt.
            Looks great!
            I also look forward to looking it over in person, with Jeff and Bonz!
            Looks like you're gonna have a "like new" 11, Jeff! Cool!
            Bob
            2011 Kaw Concours 14 ABS
              • 1261
              Oh boy.... this work has been oversold
              "like new"
              Uh Oh! I think I've got this oversold a bit. Pictures can be very deceiving. This is not going to be a like new bike but it will have some issues fixed.
              I'm just helping my friend get a few things done and the paint and etc. will make this bike look a little better but that's about it. I really wish I could wet sand and buff the tank before Jeff leaves but that's just asking for BIG trouble with no kiln room and paint only a few days old......
              Jeff won't need any more trash bags on top of his saddle bags either...
              Actually, I'm really very nervous about getting everything I offered to help with done and in good working order. I don't want my friend broke down on the side of the road somewhere between Georgia & Colorado.
              KURT
                • 1590
                I did most of the restore project mechanical work in 2012. Fortunate the engine was good but Carbs, Brakes, Calipers, Pistons, Forks, Shocks, Springs, Tires, Steering head bearings etc were junk. Spent about $3,000 on all new OEM stuff. When finished, it ran awesome in the twisties but the closer you got the worse the cosmetics looked. Got some comments about it, but nobody laughed. But for sure, not pleasant to look at when following me. Plus I never addressed the Fuse Box wiring. Had the TC box but since bike ran so great on rides from Canada to Key West I didn't mess with wiring or address the fuse box wiring issues. OR the more nasty than I though paint.
                Taken in 2012: Was never really sure where the PO was going with this
                Nuts & Bolts on bags PO gave me were mix-n-match just like most every other accessory some PO installed on the bike
                It will be great to have a cosmetically nice looking bike. New paint and most importantly for touring, bags with working seals. My old bags were leakers and latches had been put on by kids in wood shop.
                Plus they looked terrible. So THANKS Kurt. The smoking gun fuse box / wiring issues are resolved as is the nasty looking paint & leaking bags + fixing that awful hole in the dash where somebody used a hatchet to install that 1979 radio I removed in 2012 when I got the bike.
                Bike has made it to Key West twice (2K each) and Canada (3.5K) once. Plus four SE Rallies (4K). Never even carried any tools But to Colo (4K) I'll be packin'. tools
                  Jeff,
                  What have you used for seals on the saddlebags? The seals on my 'bags are hardened and have shrunk so they won't stay 'seated' and they leak.
                    • 1590
                    Originally posted by 3Phase
                    Jeff,
                    Scott,
                    PO had the bags buggered (real badly) up as you can see. Latches in wrong position too (using wood screws, couple rivets and black goop). Odd Engineering & solution. There were no proper seals on lid or bag (which made it leaks like a sive) and rattle too. All I could find was a over thick seal that I put on the upper. NOT interlocking and NOT waterproof which is why as Kurt mentioned I rode it for 4 years with garbage bags over the luggage held on by net strap. You've seen that. Its ugly.
                    Kurt's blue bags had interlocking seals so he made those bags maroon. Plan is to properly fix my latches then try to find some interlocking upper - lower seals. A winter project. I'm in NC now with family but will get you the info catalogue on the seal people in Atlanta, when I get back to Atlanta.
                      Thanks, Jeff, I thought y'all rebuilt your 'bags! Oops.
                        • 1261
                        Takin' a break for some Sweet Tea...
                        XS Folks,
                        Another PO screw up I mentioned previously.....
                        Seems the PO used an Axe to cut these holes. Honestly, I think the dummy was too lazy to remove the fairing to cut the holes properly leaving Jeff & Me with a mess to clean up. These oblong holes allowed only one screw in each speaker. Not an option, had to pull the whole thing off to fix it properly. A half-dozen bolts and the fairing comes right off.....LAZY BUTT!
                        I cut some pieces of PVC flat stock I had laying around and made some rings to cover the mess and give me something to screw into. The rings are adhered with contact adhesive and rivets. It's pretty darn solid now and I get all four SS screws to grab something....
                        KURT
                          • 1261
                          A full day... Thought I was DONE~! NOT!!!!
                          XS Friends,
                          Working all day (and most of last night) trying to get this baby done!!!
                          Had to add an additional contact block into the fairing to handle all the extra goodies (Radio, USB Charger, Aux. Driving Lamps). I also found another glass fuse (cigar lighter) that had to be upgraded to ATC. Jeff likes to store a couple spare cables in the fairing (VERY SMART idea ) Installed a little rubber deflector around my contact block to help avoid contact with those cables.
                          Replaced all the LAG BOLTS in the headlamp with M5's and proper weather seals and got 'er all buttoned up... Tank on, gas in, started right up and idles like a dream! Jeff really has this bike tuned well (I never touched it! Which is certainly a good thing!!!)
                          The new aux lamps should be helpful in BEING SEEN!
                          The photos ARE deceiving, the new paint REALLY needs a sand and buff.. It's a 10 footer..... much closer and you realize it needs a finishing touch.
                          Unfortunately, the Colorado guys will get to see it in RAW form.. Jeff will have to bring it back in a few weeks so I can buff it out....
                          As usual.... This machine is fighting me every step of the way.... Went to take it for a spin around the block and found NO REAR BRAKE! The caliper has new shoes and it WAS bled properly. It stopped the wheel on the center stand but I do recall it felt weird. With 600# of machine moving 20mph it does NOTHING! Feels like the piston is frozen. I could do the Barney Rubble or Fred Flintstone and have greater stopping power! I got about 300 yards from my drive and turned around.... DARN IT!
                          FORTUNATELY, I have a spare rear caliper from a STANDARD that I stripped out of Kentucky last year. Hopefully, Jeff's just needs to be cleaned... Worst case he get a Kentucky caliper.......
                          Got to pull the bag, the bracket, etc. just to get to the caliper UGH!!!!!
                          Gonna take a spin on DEAD DUCK and then grab an hour on the couch! UGH! The Dead Duck ride should make the day better!
                          Discouraged in Georgia!
                          KURT
                          • XJOK2PLAY
                            • 2099
                            • Skiatook, Ok.
                            Kurt,
                            You sound like some else I know...
                            Don't be too critical! From what I see, you've brought that old bike a LONG WAYS from where it was when you started. AND, everything you've addressed was much needed work!
                            I think you've made a dramatic improvement, and Jeff can ride it now with a lotta pride and confidence!
                            Can't wait to see it. Wish you were coming with him to the rally??
                            Would like to get a chance to meet ya in person!
                            Bob
                              • 1261
                              Ready for COLORADO!
                              NEXT YEAR! If Jeff goes next year, I'll see if he will let me tag-along! This year the $$$ and vacation time is not available. I'm also still "Tinkering" with my XS11's and I don't have the confidence in my bikes necessary to make this long trip.
                              XS Friends,
                              I believe JEFF is ready for Colorado.
                              Yesterday, the rear brake scared the fool out of me. I spent much of last evening; cleaning, disassembling, bleeding, disassembling again, bleeding again, & again, & again. I think I had the master off six times. FINALLY, I got all the air out and a good seal inside the master. The rear brakes on these XS11's are a pain in the butt to bleed but this one was the WORST I ever had to mess with. Had to walk away once or twice before wrenches started flying!
                              The rear brake now seems to work reliably (based upon three trips around the block) and if Jeff REALLY stands on it, the rear wheel will LOCK UP HARD. Absolutely better than yesterday.
                              Although I will probably spend a couple minutes polishing "this or that" all the work is DONE! This bike really does run well, and much better than ANY of mine.
                              Jeff is going to have a great time with ya'll in Colorado. Wish I could attend but it's just not possible this year.
                              KURT
                                NEXT YEAR! If Jeff goes next year, I'll see if he will let me tag-along! This year the $$$ and vacation time is not available. I'm also still "Tinkering" with my XS11's [I]and I don't have the confidence in my bikes necessary to make this long trip.
                                KURT
                                Just change the oils and put on good tires the bike will take care of itself. These bikes will got thousands of miles broken, even with the engine knocking.
