this just happened..(head screw broke)
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    it broke off. I have an extraction kit already, but still way freaked out about jacking up the threads inside. please help!!
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
  • mack
    • 2411
    • Ontario, Canada
    Cover bolts
    Be best to get some liquid wrench sprayed on all the bolts and let it sit over night. Remove the cover then extract the bolt. Once the cover is off you may find you have enough left to get a grip on. Spray what's left with liquid wrench , it should help.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      Might be easy
      I broke one once. Left it that way for 10 years.
      Then when I went to shim the valves, I found that there was plenty of stud exposed to grab on it. It took very little force to spin it out because there was no load on it and it was not rusted.
        • 4015
        Yeah, no worries. Get a small paor of vice grips on it, or try the double-nut trick.
        • ERM83
          • Apr 2016
          • 314
          • Lehigh Valley, PA
          right on, thanks guys! i'm gonna go mess with it in a little bit...
          79' SF carbs
          MAC 4-1
          K&N Pods
          Accel 3.0 coils
          Tarozzi fork brace
          TC fusebox
          Picture update soon
            Looks like an easy fix........remove valve cover and unscrew remaining broken allen bolt with ya' fingers.
            • HalfCentury
              • 408
              • Burlington NC
              Kroil is the best stuff on earth for loosening up decades of built up corrosion between a fastener and what is frozen to. It is not just a lubricant.
              Before I loosen a bolt for the first time, I spray it well and let it sit for at least an hour, sometimes longer and spray it again after the wait time.
              I started using it on my XJ650 and use it regularly on my XJ1100.
              82 XJ1100 - sold
              2000 ZRX1100 - sold
              2003 FJR1300 - Silver rocket
                Hate to be the naysayer of the group, but looking at the amount of bolt still left, it looks to be the same length as what was in the valve cover. He could verify that easily by just holding the remaining bolt against the outside of the hole, and see how far down it goes.
                It looks more like it broke of in the head portion. But as has been stated, there's no load/tension on it aside from the corrosion that has formed from the 2 different metals that were joined there, the steel of the bolt, and the aluminum of the head. YET apply some penetrating stuff like what was suggested, PB- Blaster, etc. Also would suggest applying some serious HEAT like from a heat gun to it, then spritz with penetrant again, repeat a few times. THEN if there's nothing left to grab, just get a fairly smaller DRILL and start drilling into it...preferably a reverse bite/cutting bit that way once you drill a little bit into it, it can start to bite the remaining piece, and will then probably just spin/back it out of the hole!
                  • 1262
                  • Peachtree City, Georgia.
                  Left Hand Bits - Best removing tool in the arsenal!
                  Looks like a tough spot to get a drill bit access to but I agree with TC whole heartedly. The absolute best broken bolt remover in the world is a LEFT TWIST drill bit. I have a full selection and have NEVER had to resort to my kit of Easy-Outs since I acquired those bits.
                  AND, whatever they put in Kroil that stuff is incredible. I don't know where to buy it but I swipe a can off my A/C Contractor every once in a while...
                  KURT
                  1982 - CBX1000 - Honda
                  • HalfCentury
                    • 408
                    • Burlington NC
                    You can buy Kroil from the manufacturer online. Kano labs. They ship it direct to your door. No muss. No fuss.
                    82 XJ1100 - sold
                    2000 ZRX1100 - sold
                      ........locally at the Ace or Tru-Valu hardware also.
