Rear wheel locked
  • dbmb0416
    • Jun 2015
    • 128
    • Westdale Ny
    Rear wheel locked
    My rear wheel locked up yesterday. Luckily only going 30mph. Took off 4 bolts hooking to it gear box which happened to go last year and replaced thinking that was same problem and still rear wheel still locked up. Any suggestions what to look for? Haven't took apart yet still on trailer? Thinking final drive but not positive. Thanks in advance.
    79 XS11SF
  • mack
    • 2411
    • Ontario, Canada
    Should be
    easy enough to figure out. If the drive shaft/ middle drive connection is free and the wheel still won't move the problem is toward the rear. If you remove the rear brake caliper, you can eliminate a brake issue. If it's still is locked up then you need to pull the rear wheel so you can disconnect the final drive/drive shaft connection to inspect.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      • 9981
      Take the wheel off, start there and work your way forward if necessary.
        +1!........and wouldn't surprise me that the middle drive is the issue.........specially if you have not previously serviced it with at least a fluid change(75-140w syn.)
        • mack
          • 2411
          • Ontario, Canada
          middle drive
          was already eliminated with the removal of the four bolts! Pull the caliper! You have to anyway to get the wheel off! If it is stuck to the disk, u know where the problem is.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
            • 3950
            First thing you should have checked for was a hot rotor.
              stuck locked up rear brake?..... wheel won't turn, so a hot dis-colored rotor is pretty much out of the question.
                • 7817
                Yeah, but he said he was going about 30mph when it happened. If you pulled the 4 bolts for the middle drive, and it's locked, go for the brakes next. I've also seen the u-joint fail and lock up the rear tire on Special Ed's bike. To check that, pull the 4 nuts at the final drive , remove the bottom shock mount bolts and pull the drive shaft out of the final drive. if it will turn, it's probably the u-joint.
                  • 9981
                  Pretty sure that's the 4 bolts he is speaking of Ray. At the u-joint.
                    Thanks for getting my attention Ray, didn't bother to go back and re-read original post before adding my post sometime later.
                    • dbmb0416
                      • Jun 2015
                      • 128
                      • Westdale Ny
                      Thanks for tips. Haven't gotten to look at bike yet since I worked last 2 days and still on trailer. That was a fun push up. I will keep posted. As said before you guys all know your stuff.
                      79 XS11SF
                        • 7817
                        Hey, a lock up at 30 is easy, try it at 85! Mine was a transmission, and the engine is still in the garage waiting for a repair.....
                          Rear wheel bearing? The special thick one? Just throwing out other possibilities. Could be welded to the axle. It's happened before.
                            • 9981
                            Had that thought too. Why I said take the wheel off and work forward if necessary.
                            • dbmb0416
                              • Jun 2015
                              • 128
                              • Westdale Ny
                              Rear wheel drive was culprit. What was weird was it would go backwards and not lock up. Had a spare and works good. Still have to finish putting together but luckily it didn't cost me anything only time.
                              79 XS11SF
