Special Exhaust?
  • Rasputin
    • 3193
    • Lacombe, Alberta, Canada
    2-79 XS1100 SF
    2-78 XS1100 E Best bike Ever
    • vedgar
      • 311
      • Clarkston, Michigan
      Special exhaust for 79
      factory chromed weld
      79 1100 SF Carmine Red stock
      85 Honda v65 Magna
        Interesting pic vedgar, but as I previously stated, won't work on 81 Venturer or 81Special as neither of that yr. model has any extension of collector in order to slip pipe on........unless a welded on 3" collector extension is added prior.
          • 9981
          What part of "replacement part" don't you understand Brant. This pipe I have came off of a Special.
            What part of post#18 did you not understand Greg?
              • 9981
              Brant, it was redesigned to FIT where the original did. This is a Yamaha FACTORY replacement but as I said, redesigned so the muffler can be separated from the header pipes.
              This one I have is the right side and it was on a Special that still had the original solid left side exhaust on it. I didn't even know there was a difference until I examined the closely.
                Okay, got it now Greg. Just was knowing that there was never an original exhaust on any XS11 that came that way from factory....cept for the XJ11.
                  • 9981
                    Images of the INSIDE of the OEM mufflers
                    Capton Zap had sent these to me a week or so ago, finally got around to putting them up on the site's server, and thought this would be a good place/thread to post them! They show the complexity of the OEM mufflers and it's internal baffle system!
                      • 9981
                      That's interesting TC. Much more complicated than I imagined but they must be engineered to be free flowing.
                      These are the baffles that are in the brand new Mac flare tip exhaust I just put on my bike. I've been running a noisy straight through set of short mufflers and the bike runs GREAT with them since I discovered the power loss I was having was because of exhaust restriction in the Mac turnouts I had on there.
                      Even these are too restrictive. I put the new system on with the mufflers with these and my WOT stumble was back again. I am building some straight through perforated baffles that will basically be glass packs only they will be packed with SS wool.
                        Hey Greg,
                        The 4-1 Mac system I have doesn't even have that convoluted style of baffle, just a straight vented tube going to the end plate. Instead of MAKING baffles, why not just VENT/Drill the ones you have thru the sides of the tubes??
                          • 9981
                          That is the exact baffle that was in my Mac 4 into 1 on the green bike. It had the same stumble but not quite as bad as I recall.
                          I hated the way it sounded.
