Can anyone tell me what tank this is?
  • thruxtones
    • Apr 2016
    • 11
    • Ajax, Ontario, Canada
    Hey I know there's some gurus here who would be able to tell me what year this.
    Ultimately I need to find a gas cap/door and petcock.
    I appreciate all the help
    Thanks!
    '04 Triumph Thruxton
    • 8062
    It appears to belong to a 1979 XS1100F.
    • thruxtones
      • Apr 2016
      • 11
      Thanks Marty
      When I bought it at the salvage the guy did guess at 79' but said not to quote him. Prolly to defer any onus on the parts that I need to find.
      Hoping someone here could flat out say it is or at least say that you could purchase the parts you need from 78'-82'
        Originally posted by thruxtones
        Thanks Marty
        ....actually, 78-81Standard(E,F,G,H), not Special 79-81(FS,GF,HF).
          Thanks Marty
          Hi Thruxtones,
          The gas cap and surround are the same for standard tanks from 78 to 81.
            Sorry Thruxtone, that last should be SF,SG and SH for the Special designations.
            • Eveready1100
              • 539
              • Childers, Queensland,Australia
              Hi Thruxtones,
              Any chance of another photo taken to show the side profile??
              I'm thinking you may have chanced upon a Venturer tank judging by the front curve from the filler neck to the frame tunnel, but I can't see it properly from the photos you've posted.
              Oh, and welcome aboard, mate!
                Originally posted by Eveready1100
                Hi Thruxtones,
                Doubtful, the pinstripe looks too rounded st the front to be a '81 tank.
                  It is just the Standard model tank, not the bit larger capacity Venturer tank, which was one yr. only. Also, the stock colored Venturer tank was pearl white around inside of pinstriping where knees ride.
                  • thruxtones
                    • Apr 2016
                    • 11
                    Hi Thruxtones,
                    Thx for the warm welcome!!!
                    • thruxtones
                      • Apr 2016
                      • 11
                      Thanks for the input guys. Couple more questions is it possible to find brand new petcocks?
                      If not is there a way to tell if you're looking at a pic whether it is left or right side?
                      And would a petcock off a special be compatible??
                        • 2098
                        Yes, Yes and . . .
                        . . . not sure if the Special petcock will bolt up to a Standard tank but this link:
                        is where I'm presently fixin' on securing parts for a Standard petcock rebuild.
                        On the right chrome cover plate and I believe on the petcock lever is a small "R" indicating . . . well right side.
                        • thruxtones
                          • Apr 2016
                          • 11
                          That's great information!! Much appreciated!
                          Thanks schming!!
                          • thruxtones
                            • Apr 2016
                            • 11
                            Thanks schming!!
                              • 8893
                              The Special and Standard fuel taps DO NOT interchange. The bolt pattern is different.
