Oil filter gasket
    Originally posted by dbmb0416
    What's the size washer I should get for the oil drain plug? That's the one thing I don't have. Thanks for all the help.
    Preferably a copper washer, and one that fits snugly over bolt threads.
      • 2140
      What Washer?
      None of my 4 XS's have a washer on the oil drain plug, and I have no leakage. I have owned one since it was a year old, so I think there never were washers in my bikes.
      However, can't hurt.
      • dbmb0416
        • Jun 2015
        • 128
        • Westdale Ny
        Some has said it helps not to over tighten and not strip it.
        79 XS11SF
        • CatatonicBug
          • 6117
          • Clinton, UT
          Yeah, mine doesn't have one either. Never had any issues with it. I think the problems happen when a bike sits in a barn for 5-25 years and the metals just corrode together and get stuck.
          • MPittma100
            • Aug 2011
            • 2359
            There is supposed to be a washer on the engine oil, middle gear, and final drive drain bolts. I believe the OEM washers were made of aluminum. You will be smart to use a washer in these areas. Copper, aluminum, or Teflon are good choices. Even a spark plug seal ring will suffice (14mm) for oil pan bolt.
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              Hmmm..... must of got lost prior to your ownership. Originally, all the XS series had a thin stainless steel washer on oil drain plug like on the middle drive and final drive drain bolts. My Venturer still has the original washers on the middle and final drive drain bolts since buying the bike new, Years ago, I replaced the crankcase drain bolt washer with a copper one since original stainless steel one was getting groove marked.
                • 2140
                Yup
                ...So I checked the parts diagrams for all my bikes and saw they all show a washer.
                I'll have to grab some next time I place an order.
                  • 5073
                  I think I use a 14mm nylon washer. It will hold up to the heat and help prevent stripping the plug threads because you don't need to torque it too tight. Just don't get carried away with over-tightening the filter bolt!
