Oil filter gasket
  • dbmb0416
    • Jun 2015
    • 128
    • Westdale Ny
    Oil filter gasket
    Attempting first oil change this week. Have Napa oil filter with both gaskets. Question before I take apart. The small gasket goes around bolt first and then put bolt through the housing? Then spring,washer and finally filter. Of course large gasket is pretty self explanatory. Thanks
    79 XS11SF
    Yes, what you said is 100% correct.
      Yep, you got it. Washer touches the filter. Always make sure you actually get the O-rings in the box with the filter before trashing the old ones. Sometimes, the small one disappears.
      • dbmb0416
        • Jun 2015
        • 128
        • Westdale Ny
        Thanks. Got 2 filters thru Napa for that hopefully 6k miles this year.
        79 XS11SF
          Originally posted by dbmb0416
          6k miles this year.
          I used to be in that boat. I'm sorry that's all you get...
          • dbmb0416
            • Jun 2015
            • 128
            • Westdale Ny
            Ha. I only got 450 last year.
            79 XS11SF
              Incorrect.......small gasket goes topside of filter over bolt, and O-ring goes on slotted portion of bolt.
                Oh I'm sorry motoman, I thought he had it correct, my bad.
                  No problem, had ya' covered.
                    Gasket? What gasket? All I have seen are Oring seals and Oil filter in the box.
                      Hey guys,
                      The Original Poster just used slightly incorrect terminology...calling the O-rings Gaskets. There are NO gaskets in the oil filter kits....just the small O-ring for the filter bolt, and the large O-ring for the CUP.
                      BTW, if you have trouble keeping the large ring in the cup, you can apply some grease into the groove to help the O-ring stick in there, and others have recommended putting the O-ring in almost boiling hot water for a few minutes to help make it more pliable!
                      • dbmb0416
                        • Jun 2015
                        • 128
                        • Westdale Ny
                        Sorry meant to say o rings. If I take out carefully I should see how everything goes back in. All bolts look good so hopefully no rounded heads on either filter housing or oil drain plug.
                        79 XS11SF
                          Hi dbmb0416,
                          I use a 6 point socket to preserve the filter bolt. Has worked so far I prefer to remove the filter first as when it drops in the empty catch pan it is much easier than if it falls in the dirty oil. Retrieve the washer that has embedded it's self in the filter. Find the spring.
                          When installing the filter cup you need to ensure it seats properly......or the fresh oil sprays all over the floor DAMHIK
                          There is a small tongue that prevents the cup from spinning when aligned with the fins. I push and hold the cup up in to place then continuing to hold I tighten the bolt. Be very careful with the drain plug as many of us have stripped them. Use a fresh copper or nylon washer.
                          Remove the O rings from the filter carton and lay on a flat surface. It will soon find it's natural shape and not fight you installing it in the groove.
                          A dab of oil will hold it in place.
                            JAT.....outer O-ring on filter housing hasn't looked flattened for several yrs. and a whole lot of oil changes on my Venturer as of yet, and falls right back in place in the groove with no leakage. Same goes for the smaller O-ring on the housing bolt. Consequently, have several new filter housing O-rings hanging up. Not the normal advised option, but has worked fine so far.
                            • dbmb0416
                              • Jun 2015
                              • 128
                              • Westdale Ny
                              Hi dbmb0416,
                              What's the size washer I should get for the oil drain plug? That's the one thing I don't have. Thanks for all the help.
                              79 XS11SF
