SG Fork Oil - Correct Amount?
    • 1954
    I have Clymer's manual for my SG but no factory manual for it.
    The Clymer's doesn't clearly indicate how much front fork oil is correct for an SG.
    It says:
    E/F = 7.17 oz
    SF = 7.61 oz
    G/H = 8.15 oz
    SH/LH = 7.10 oz
    ....but no SG??
    I also wondered if I need to consider my bike seems to have long springs, (probably for the fairing),... wondering it the extra windings displace enough oil to be a consideration. There is about 1.5" pre-load without any weight on them.
    Did a quick search and didn't see any recent discussion.
    Anybody know the correct amount of fork oil for an SG?
    Thanks.
    • 8681
    The 80 special takes 210cc per leg, slightly increase the level if you are experiencing front end dive during braking.
      • 9980
      7.1 oz give or take. Just go to the dollar store and get one of those cheap plastic measuring cups, take a sharpie and put a mark at a little over 7 oz.
      That's how I do it anyway.
        • 7794
        Remove the springs. Collapse the fork. Fill until 130 mm from the top. As Phil said, 10 to 20 more millimeters to reduce dive if necessary or desired. Nope. It's not in the book.
          • 1954
          7.1 oz = 210 cc
          Thanks guys!
          I have a little squirt bottle with graduations on the side. I use it to squirt the correct amount from the bottom before I replace the allen head bolt.
          Marty's method is interesting. Wonder how it come about?
            • 9980
            Thanks guys!
            Hmmmm.........much easier to just pour it in from the top with the cap removed.
              • 1546
              Thanks guys!
              That's how Traxxion Dynamics set up my 11E forks. In measured mm from top of fork to fluid -not- volume cc. If you look at the Race Tech specs that how Race Tech does it. He has a Special with Race Tech emulators.
              They (Traxx Dyn) set mine up at 120 mm down the fork to the fluid. With 10wt Left fork and 20wt Right fork. I just changed my fork oil and out of curiosity measured the amount that came out. It was approx 8 oz both L&R that drained out.
                • 9980
                Originally posted by JeffH
                [/B]
                Why different weights side to side? Seems that would throw it off.
                  • 1546
                  Its not independent suspension. Forks function together tied with that front axle. Since I have emulators to adjust the compression side they are using the varying weight of the L & R side fork oil to control the rebound rate. Their procedure is to dial in Rebound rate first, then set the emulators for compression dampening.
                  It really is an awesome setup. Traxxion Dynamics has me setup full race. Its very very stiff and not for everybody but we are in smooth roads and lots of curves. btw: they have both L& R emulators set at 4.00 turns so in compression L & R are not equal either. These are the race guys and that seems how they are setting up suspensions on these bikes.
                    • 9980
                    I have stock forks with 15w in both. They work good.
                    It took a little getting used to the stiffer front end but I was able to find the sweet spot with fork air pressure adjustments. 18psi is pretty right.
                      Pertaining to my Venturer, which is stock and original, 20w fork oil and no air pressure added. Over the dacades of use the dampening orfice from oil passing thru at high speed, orfice tends to get slightly enlarged from oil friction(which is what causes heat). Works excellent, bike loaded heavily or fairing empty. Years prior, I had them rebuilt using 10w fork oil and 15psi air pressure. A bit stiffer now using 20w and no air pressure added, but corner and stopping handleing is greatly improved.
                        • 8681
                        I run 30W with emulators, nice heavy rebound damping but less compression damping that way. Really improves the handling, YMMV
                        Oil level is 6" from the top, fully compressed.
                          • 1954
                          Is there a better technique?
                          I felt it would be easier to get the cap back on before I reassembled the inner tube into the outer tube....that way I could push on the inner tube to compress the spring and brace the bottom against a board.
                          You must put the whole fork back into the triple tree first to hold the inner tube while you put the cap on, pushing against the spring?
                          Maybe I think too much.
                            • 9980
                            Naw I have the tube clamped in a vice hanging and the cap with a small pair of vice grips. All assembled you only have to overcome about an inch of the spring.
                              • 2072
                              FWIW, I put the cap in the vise with protective jaws and spin the tube onto it.
                              It's easier than trying to push that cap 'cause you have the whole fork tube to push with
