79' Carbs Hose Identification
  • neJeff
    • Jun 2011
    • 346
    • Nebraska
    I started this bike 1 1/2 years ago and didn't make adequate notes when I pulled the carbs off. Please tell me (as you see it in the picture) which "T" fitting is the fuel and which is the air. I can't remember.
    Current Daily Rides / Projects
    1979 Yamaha XS1100F (since 2015)...Project
    1980 Suzuki GS850G (since 2012)
    1979 Kawasaki KZ400B (since 2013)
    • 9980
    The one closest to the top of the carb is the vent, the one closest to the float bowl is the fuel inlet.
    You've got some serious cleaning to do there. I hope all the jets and emulsion tubes will come out.
    • MadHatter4119
      • Nov 2014
      • 137
      • Baltimore, MD.
      Those are as bad as mine were...put them in a ultrasonic tank...Call around
      to your local shops...one of them should have one and clean the internals once
      you take the other parts off...Keep us posted with more pictures...Good Luck
      79 XS 1100 Special "Basket Case"
      • neJeff
        • Jun 2011
        • 346
        • Nebraska
        Thanks guys, really appreciate it! These are one the dirtiest sets I have seen but I am on the 4th carb and only twisted off one main jet and two rail screws.
        I am dipping in Berrymans and also ultrasonic cleaning these and they have been a challenge!
        Thanks for the hose identification!
          • 8767
          This is not good for the butterfly shaft seals, better take them out first or you may need to replace them, if they leak air the bike will never run right.
            • 2078
            Berrymans is my #1 go to spray carb cleaner, best on the market, but if your dipping your carbs in it plan on replacing the butterfly shaft seals also.
            In fact every set I refurbish the shaft seals get replaced
            Your carbs look challenging but they'll clean up nice, GL
            HaHa I run to get a coffee and Phil slides one in there.
