Rebuilding Carbs on a 79'
  • neJeff
    • Jun 2011
    • 346
    • Nebraska
    These things are giving me fits. Twisted off two rails in disassembly, twisted off one main jet and lost another pilot jet ( it got away from me). Dirtiest set I have ever seen. Can someone tell me what the main & pilot size is? Also is there not suppose to be a o-ring and washer on the mixture screws or is it a tapered fit or what? I'll probably have more questions...thanks in advance
    Current Daily Rides / Projects
    1979 Yamaha XS1100F (since 2015)...Project
    1980 Suzuki GS850G (since 2012)
    1979 Kawasaki KZ400B (since 2013)
  • mack
    • 2411
    • Ontario, Canada
    79 carbs
    mains are 137.5 pilots are 42.5. No o ring and washer, just a spring.Yes sort of on the taper fit.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • neJeff
      • Jun 2011
      • 346
      • Nebraska
      Thank you very much, now to find me a couple of jets. I can't even read the 42.5 with a magnifying glass, where is it marked?
        Located on the side of pilot jet. Magnifying glass would likely be needed in order to read it.
        • neJeff
          • Jun 2011
          • 346
          • Nebraska
          Had to drill out the last pilot jet. Luckily I found that I had a couple of 42.5's to replace this one and the one I lost. Going to order a 137.5 main.
          Anyone happen to know what the tap size for the pilot is? Going to run in through and make sure threads are good. I can figure it out tomorrow if no one knows off hand
