oil filter bolt length
  • MadHatter4119
    • Nov 2014
    • 137
    • Baltimore, MD.
    Don't know for sure unless you ask...But no I didn't...Have you used a oil
    cooler before on a inline engine ?
    79 XS 1100 Special "Basket Case"
    • Eastcoaster
      • Jan 2012
      • 508
      • oceancity NJ
      What I meant you did not put this back on the bottom of the engine before you tried to install the filter and bolt? It only belongs if you have an oil cooler and I thought you said you removed a cooler just want to make sure
      82 XJ1100J
      81 Venturer
      • MadHatter4119
        • Nov 2014
        • 137
        • Baltimore, MD.
        How do you guys post those large pictures...I took that bolt out with the
        plate the hoses screwed into...I'm screwing the cover / filter bolt into the
        bottom of the engine...even with the two tabs lined up...the bolt bottom out
        before sealing to the engine...its either the bolt is wrong or the cap that holds
        the filter is wrong...???
        • Eastcoaster
          • Jan 2012
          • 508
          • oceancity NJ
          sent you measurements on both let me know what you find
          82 XJ1100J
          81 Venturer
          • Eastcoaster
            • Jan 2012
            • 508
            • oceancity NJ
            Sounds like we have a solution!
            82 XJ1100J
            81 Venturer
              • 9981
              Here's a few of the oil filter bolt hole on the bottom of the case.
              Not a good pic but here is the bolt hole threaded all the way to the bottom....
              Measured to where the bolt would bottom out it's about 27mm...
              The length of the thread is about 24mm, that's about an inch.........
              So the bolt can't bottom out but it can theoretically run out of thread. Did you check the threads in the case? Did you try to screw the bolt up in there without the cup to see if it's going all the way? It should screw in all the way to the end of the threads on the bolt by itself.
              • MadHatter4119
                • Nov 2014
                • 137
                • Baltimore, MD.
                Thanks East...I still need to learn how to post pictures here...It's the cover...Now I want to know what it came off of...Looks the same as a XS
                one...but only 44.0 or 45.0 as opposed to the one above...Thank All
                  • 9981
                  • Eastcoaster
                    • Jan 2012
                    • 508
                    • oceancity NJ
                    Harrys
                    The right size
                    82 XJ1100J
                    81 Venturer
                      • 9981
                      Open a photobucket account and upload your pics to your library from your phone or your computer.
                      A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                      Just remember, if you delete any pics you've posted to .com from your photobucket account they will no longer show on the forum either.
                        • 9981
                        Yeah, I missed that when I was posting the other. If that's the case then the stock replacement bolt must stick WAYYYY more up over the mating surface than a couple threads like my pic before shows.
                        • MadHatter4119
                          • Nov 2014
                          • 137
                          • Baltimore, MD.
                          I have pictures on photobucket...but were the link to attach a photo to this post...I tried to drag & drop from my computer...I'm using a Mac Book Pro
                          and I resized a photo in iPhoto...now how do I attach it to a reply to a post...???
                            • 8931
                            Paste the address of photo between [img] [/img] brackets in your post.
                              • 9981
                              When you pull up a pic on photobucket hover the cursor over the top left corner of the pic and a drop down will appear. Chose "share" from the list, in a moment a "share the photo" window will appear. From that list click on the 'IMG' code. It will turn yellow and say "copied". From there you can go back to your .com post and paste it in the post where you want it to appear.
                              • MadHatter4119
                                • Nov 2014
                                • 137
                                • Baltimore, MD.
                                So , Posting a picture from my computer isn't doable...the above little yellow box insert image only permits an http address...photobucket...oh well...I'll check
                                youtube to see if they have any Photobucket how to...
