oil filter bolt length
  • MadHatter4119
    • Nov 2014
    • 137
    • Baltimore, MD.
    I removed a oil cooler set up that was on this 79 XS 1100 Special basket case when I got it. I found a stock set up with the cover, bolt , spring and washer. I than purchased a Fram CH6002 oil filter...I put the bolt through the
    cover, put on the spring than washer...than oil filter...My problem is my bolt bottom out before the cover seals to the engine...as if the bolt was to long or
    something...What the Hey am I doing wrong ??????? Thanks
    79 XS 1100 Special "Basket Case"
    The bolt for the oil filter housing IS a special one having an o-ring groove. Not just a regular bolt will work. It is specificly made for that location.
      • 8931
      This is the correct bolt for a non-cooler setup....
      http://www.ebay.com/itm/EMGO-Yamaha-...BUeijI&vxp=mtr
      • MadHatter4119
        • Nov 2014
        • 137
        • Baltimore, MD.
        That's a replacement bolt...I have a stock bolt...but when it bottom out...I have a 1/4 gap between the cover and engine...
          • 9981
          I have a filter canister w/bolt on my toolbox at work and a digital caliper to measure it. I'll get those dimensions for you in the morning.
          Meantime, take your replacement bolt by itself and screw it into the engine. Will it go all the way in as far as the bolt is threaded?
          If not, check to be sure the threads in the engine case aren't boogered up.
            • 9981
            Here's a pic of a canister with a OEM bolt. Only a couple threads stick up past the mating surface. Those 2 little tabs in the foreground on the cup go back towards the oil pan and fit up in there so the cup cant turn.
            • MadHatter4119
              • Nov 2014
              • 137
              • Baltimore, MD.
              I'm not sure my cover is the same as the one in the above picture...Do
              they differ with years & models between the XS11's ??? It could be just the
              picture...? I wish I was better at loading pictures here...
              • MPittma100
                • Aug 2011
                • 2359
                Oil filter
                The two tabs mentioned on the filter can are most likely causing your problem. They go towards the rear of the engine and have to be clocked just right in order for the canister to mate properly with the block.
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
                • MadHatter4119
                  • Nov 2014
                  • 137
                  • Baltimore, MD.
                  I think you are correct..Sunny and 70 degrees today...rainy and cold for the next 5 days...chance of snow Sunday...First day out spring...enough with this
                  crazy weather...I'll give it a go with this info...I'll get those tabs in their place,
                  than tighten the bolt...thanks
                    • 9981
                    All the cups are all the same all years, XJ too.
                    • MadHatter4119
                      • Nov 2014
                      • 137
                      • Baltimore, MD.
                      Thanks All...
                        • 9981
                        You still want me to measure that bolt or was the pic enough?
                          • 4013
                          I think you got him squared-away with those tabs. Common mistake.
                          • MadHatter4119
                            • Nov 2014
                            • 137
                            • Baltimore, MD.
                            Well we me...it appears its never that simple...even with the tabs lined up...
                            this piece of crap cover still won't go on...I'm getting to the end of my rope
                            with this bike...The picture of the cover above looks a little deeper than mine
                            ...I'm not sure if its the cover or the bolt...My phone ( iPhone 5 ) doesn't seem
                            to have any setting that makes the pictures smaller so i can post a picture...I
                            look below and didn't see a link below to attach a picture to this post...How do
                            I attach a picture once I figure out how to make them smaller...? I try using
                            the forum search bar...but that was a waste of time...it gave me everything but
                            how to post a picture...Crazy
                            • Eastcoaster
                              • Jan 2012
                              • 508
                              • oceancity NJ
                              I gotta ask
                              I gotta ask but I am sure you did not put the bolt that mounts the oil cooler back in?
                              82 XJ1100J
                              81 Venturer
