More fun
  • aquamantx
    • Aug 2015
    • 198
    • Montgomery, TX
    More fun
    Well I was wondering why rear brake didnt work properly.
    81 LH in process
    09 vstar 1300
    only allowed 2
  • aquamantx
    • Aug 2015
    • 198
    • Montgomery, TX
    Should I use some brake cleaner?
    81 LH in process
    09 vstar 1300
    only allowed 2
      • 9980
      Clean it up as best you can with a wire brush or whatever works and go to Wally World and get a gallon can of carb/parts cleaner dip. About $20.
      Remove the reservoir and soak the body of the M/C for 2 or 3 hours and it'll loosen that crud up. Repeat if necessary.
      The parts cleaner is quite useful for cleaning up lots of stuff.
      If your M/C (s) looks like that, the caliper(s) will also. And flush out the brake lines with spay brake cleaner.
      • aquamantx
        • Aug 2015
        • 198
        • Montgomery, TX
        Thanks for the info. I was planning on flushing all of the lines and rebuilding the master but as you know they do not make the kit for the rear anymore.
        81 LH in process
        09 vstar 1300
        only allowed 2
          • 9980
          Try this one until you find another......
          Partsnmore offers premium motorcycle and ATV parts for Honda, Yamaha, Kawasaki, and Suzuki models. Shop top-quality OEM replacements, aftermarket, performance parts, and accessories at unbeatable prices. Enjoy fast shipping, expert advice, and trusted products to keep you riding smoothly. Shop now for the best deals!
          • aquamantx
            • Aug 2015
            • 198
            • Montgomery, TX
            thank you. great information
            81 LH in process
            09 vstar 1300
            only allowed 2
              • 3192
              Treat your present rear master parts with a lot of care until you can compare them to the new ones. You may still need them, I have ordered a set before to fit a LH and found the advertised kit did not fit.
              When it comes to bleeding that brake system from empty you may want to try a windshield washer pump and some hose. I did it using those items and could circulate the brake fluid until there was no air in the system in a few short minutes. I posted it somewhere on here quite a while back. It worked slick as all get out.
              • aquamantx
                • Aug 2015
                • 198
                • Montgomery, TX
                Thanks for the information. Yep keep the old untill you check the new. Working with that on the carbs. Rookie mistake.
                81 LH in process
                09 vstar 1300
                only allowed 2
                • Prisoner6
                  • Aug 2013
                  • 1184
                  • Phoenix, AZ
                  Originally posted by Rasputin
                  ... When it comes to bleeding that brake system from empty you may want to try a windshield washer pump and some hose. I did it using those items and could circulate the brake fluid until there was no air in the system in a few short minutes. I posted it somewhere on here quite a while back. It worked slick as all get out.
                  For anyone interested, here is the thread in which Rasputin explains his 'windshield washer pump' bleeding technique (pic included):
                  Brake Bleeding question
                  There is also some other discussion about bleeding techniques.
                  Marco
                  1979 Honda CBX
                  2002 Kawasaki ZRX1200R
                  WE MISS YOU, DON
                  • BardGriffin
                    • Jul 2015
                    • 15
                    • Denver, Co.
                    That's a fantastic idea! Thanks!
                    79 F Cafe` project
                    • aquamantx
                      • Aug 2015
                      • 198
                      • Montgomery, TX
                      I have a can of Chem dip but I concerned about the sight glass.
                      81 LH in process
                      09 vstar 1300
                      only allowed 2
                      • mack
                        • 2411
                        • Ontario, Canada
                        Cleaner
                        Put it in pot of boiling water after the reservor is removed. Boil it for about five minutes. Let cool rinse well then blow out with compressed air. Repeat until spotless.
                        mack
                        79 XS 1100 SF Special
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        https://youtu.be/wB5Jfbp6SUc
                        https://youtu.be/RaI3WYHSuWA
                        Frankford, Ont, Canada
                        613-398-6186
                        • aquamantx
                          • Aug 2015
                          • 198
                          • Montgomery, TX
                          Thanks for the tip. FYI on the midnight special ( at least mine ) the unit is one solid piece no reservoir to separate.
                          81 LH in process
                          09 vstar 1300
                          only allowed 2
                          • mack
                            • 2411
                            • Ontario, Canada
                            Linked brake
                            Sorry , didn't see it was a midnight. I got rid the linked brake system on my Midnight. The idea just gives me the creeps. Tough to get parts and if the proportioning valve is not right the system will fail. Make sure you clean that valve very well. I've kept all the pieces from mine, if you need anything let me know. Think I still have the solid tube as well but I tried to paint it gold and turned out like crap.
                            mack
                            HERMES
                            original owner
                            81 XS 1100 LH MNS
                            SPICA
                            78 XS 11E
                            IOTA
                            613-398-6186
                            • aquamantx
                              • Aug 2015
                              • 198
                              • Montgomery, TX
                              Been admiring your mns. That's were mine needs to be. How did you paint the jugs? Little wary about pulling them.
                              81 LH in process
                              09 vstar 1300
                              only allowed 2
