carb emulsion tubes location
  • MadHatter4119
    • Nov 2014
    • 137
    • Baltimore, MD.
    Hi...I have two different sets of main jet emulsion tubes...one set has 4 x 4 holes in it and the other has far less hole...which carb does the 4x4 tubes go into...??? Thanks
    1979 XS 1100 Special
    79 XS 1100 Special "Basket Case"
    • 8930
    The tubes with less # of air bleed holes (richer) go in the center 2 carbs, #'s 2+3. This is done to help keep the temperature cooler on the 2 inboard cylinders.
    • MadHatter4119
      • Nov 2014
      • 137
      • Baltimore, MD.
      Thank you...
      • MadHatter4119
        • Nov 2014
        • 137
        • Baltimore, MD.
        Well , I managed to clean the carbs...not without issues...didn't pay attention to the emulsion tubes and I lost the little clip/washer that
        holds the clutch lever to the rod...Once I locate a replacement left side
        drain plug...put the carbs on...try to fire it and do a compression test...
        if I get a good reading...I may try to locate a better set of carbs...What
        is the going rate for a set for a 79 XS 1100 special carbs...provided I
        can find a set...??? The ones that came with bike has been severely and
        I mean severely abused / neglected...I got everything moving again and
        hope clean enough for it to run...we will see...Thanks again !!!
        • TADracer
          • May 2006
          • 1417
          • Kenner, Louisiana USA
          Remember, look at what you are buying very carefully because another set of 79 Mikunis are still a set of 37 year old carburetors.
          Some here (myself included) have changed over to more modern 1998-2002 Kawazaki ZRX 1200 carbs. They need very little modification to plug and play and their ease of tuning and ability to hold a tune will astound you (my humble opinion). Either way, be careful what you buy and get a hands-on inspection if possible before you part with your hard earned $$
          Mike Giroir
          79 XS-1100 Special
          • MadHatter4119
            • Nov 2014
            • 137
            • Baltimore, MD.
            It appears that a 98 Kaw ZRX 1200 has 4x Keihin CVK36...I'll have to do a
            little research to see what needs to be done to get them working on a XS...
            Thanks for the tip...
