carb emulsion tubes location
  • MadHatter4119
    • Nov 2014
    • 137
    • Baltimore, MD.
    Hi...I have two different sets of main jet emulsion tubes...one set has 4 x 4 holes in it and the other has far less hole...which carb does the 4x4 tubes go into...??? Thanks
    1979 XS 1100 Special
    79 XS 1100 Special "Basket Case"
    The tubes with less # of air bleed holes (richer) go in the center 2 carbs, #'s 2+3. This is done to help keep the temperature cooler on the 2 inboard cylinders.
    • MadHatter4119
      • Nov 2014
      • 137
      • Baltimore, MD.
      Thank you...
      • MadHatter4119
        • Nov 2014
        • 137
        • Baltimore, MD.
        Well , I managed to clean the carbs...not without issues...didn't pay attention to the emulsion tubes and I lost the little clip/washer that
        holds the clutch lever to the rod...Once I locate a replacement left side
        drain plug...put the carbs on...try to fire it and do a compression test...
        if I get a good reading...I may try to locate a better set of carbs...What
        is the going rate for a set for a 79 XS 1100 special carbs...provided I
        can find a set...??? The ones that came with bike has been severely and
        I mean severely abused / neglected...I got everything moving again and
        hope clean enough for it to run...we will see...Thanks again !!!
        • TADracer
          • 1417
          • Kenner, Louisiana USA
          Remember, look at what you are buying very carefully because another set of 79 Mikunis are still a set of 37 year old carburetors.
          Some here (myself included) have changed over to more modern 1998-2002 Kawazaki ZRX 1200 carbs. They need very little modification to plug and play and their ease of tuning and ability to hold a tune will astound you (my humble opinion). Either way, be careful what you buy and get a hands-on inspection if possible before you part with your hard earned $$
          Mike Giroir
          79 XS-1100 Special
          • MadHatter4119
            • Nov 2014
            • 137
            • Baltimore, MD.
            It appears that a 98 Kaw ZRX 1200 has 4x Keihin CVK36...I'll have to do a
            little research to see what needs to be done to get them working on a XS...
            Thanks for the tip...
