VFR Coils huh? will they fit right in place?
i started to take apart the coils only to not find my voltmeter (i just moved). I ordered one on amazon. so i wont know if they are bad until saturday. as far as cables, all connections look good snd nothing melted by the fuse box.
. I just get lazy typing more info and assume folks here understand more than I would expect at times. Also, I might add that even though the VFR coils will bolt right to frame using the same bolts and mounting holes, some are 1.5ohm and others are 3ohm. So they need to be checked across the two poles with an ohm meter prior to purchase. If one would like to use the original same coil wire plug-ins, unsolder the wires from original coils and re-solder them to replacement coils using shrink tubing over the re-soldered location for insulation so they don't ground to frame when bolted back on
