engine weight
  • Eastcoaster
    • Jan 2012
    • 504
    • oceancity NJ
    engine weight
    Looking for the approximate weight of the engine out of the frame I have to get one in my pick up and wanted to know about what I would be dealing with.
    Thanks!
    82 XJ1100J
    81 Venturer
  • mack
    • 2411
    • Ontario, Canada
    weight
    It's only a bit over a couple hundred pounds, but it's awkward as hell. If you have a friend and a couple metal poles, you can slip the poles through the front upper and rear motor mount holes. This will make it easier to load and unload and if you clamp the poles in place it will keep the motore from tipping over. The weight can be reduced though by removing the head, clutch basket, middle drive, starter, carbs and generator. Your wife or girl friend would then be able to easily assist in the lifting.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      • 9980
      Thought it was closer to 300#.
        • 9980
        Thanks!
        You'll need help unless trbig is there.
          Actually BA80 IS really close. Motor and tranny being 280lbs. is STILL a narly heave.......of which I'll pass on lifting more than two inches. As Greg stated, unless your trbig.
          • Eastcoaster
            • Jan 2012
            • 504
            • oceancity NJ
            Weight
            I have never had one out of the bike . I picked up the 1979 XS110 Standard - 1 owner on the for sale site and it comes with an engine.
            Its a long trip and I wanted to have an idea what I will be dealing with. I have nowhere near the super strength of Trbig.
            Thanks!
            Gordon
            82 XJ1100J
            81 Venturer
              • 1246
              • Peachtree City, Georgia.
              Be Careful!
              Originally posted by motoman
              Motor and tranny being 280lbs. is STILL a narly heave.......D.
              Gordon,
              I purchased an XS11 motor last week and it took three men to get it in the trunk of my car (a comparable height +/- to a pickup bed). I took some GOOD rope of about 1/2" diameter with me and ran it through the motor mounting holes front and rear (remove the rubber isolators) which provided very nice lifting handles There was really no good place to get a sure lifting grip on the motor without it..
              That motor was every bit of 280# as motorman indicated. Take it from a guy that had back surgery.....Get the extra help!!!! Even if you have to slip the next door neighbor a $20 for 5 minutes of his time..... FIND THE EXTRA SET(s) of HANDS!!!
              Very Sincerely,
              KURT
                I was always told (Never weighed one) that it was only 225 pounds. I have joked in the past with my neighbor, who had a GSXR 1000 that my bike sitting there with the motor out still weighed what his complete bike weighs. lol.
                • rdmcguy
                  • Jul 2013
                  • 515
                  • Denver, Colo.
                  Too much
                  My guess would be about 225 too ,
                  A ball buster to even try by yourself , A bit of a struggle for two guys,
                  Usually nice and greasy too, to add to the fun !!!
                  • mack
                    • 2411
                    • Ontario, Canada
                    Weight
                    Here’s the weight broken down, I used a digital and analog scale to determine the weight of each component to reduce error as much as possible. All measurements are imperial
                    Crankshaft -23
                    Clutch (complete)-8
                    Mid drive-11
                    Jugs- 14
                    Head (bare)-20
                    Upper/lower cases with shift drum , bearings and kick start mech. installed-39
                    Starter-4
                    Generator-6
                    Con-rods and psitons-4
                    Drive axel-5
                    Main axel-3
                    Primary shaft- 8
                    Middle driven gear and oil pump-3
                    Clutch cover and misc. parts- 4
                    Rotor-4
                    Hyvo and cam chain-2
                    Cams and valve train components-5
                    Bank of 78 carbs -6
                    Total weight here is approx. 170 lbs. This leaves 30 lbs for 4 quarts of fluid, cover fasteners, gaskets, shifter, timing cover and oil pan.
                    It seems heavier because of how awkward the weight distribution, and the difficulty in transferring the mass into the frame. I would rule against the rope through the motor mounts method of movement. Go with the hollow metal tubes through the motor mount holes. Use the lowers front and rear if possible to provide easy of lift and stability in the truck bed. Ropes hurt the hands and the motor will shift due to the weight distribution inequity. An easy two man job.
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
                      Crankshaft -23
                      Clutch (complete)-8
                      Mid drive-11
                      Jugs- 14
                      Head (bare)-20
                      Starter-4
                      Generator-6
                      Drive axel-5
                      Main axel-3
                      Primary shaft- 8
                      Rotor-4
                      Bank of 78 carbs -6
                      They built them lighter for u'all northerners.
                      • mack
                        • 2411
                        • Ontario, Canada
                        Lol
                        Yes Motoman, I've heard that everything gets heavier the closer to the equator you get! It's that damn gravity!
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                        • webbcraft2150
                          • Sep 2002
                          • 1605
                          • AUSTIN.TX
                          Weight seems to be in direct relation to how many people you have to help you. I know when my XS runs out of gas and I have to push it (rare occurrence thankfully), it instantly gains about 300 lbs.
                          • mack
                            • 2411
                            • Ontario, Canada
                            weight
                            Manage abilty is also directly inversely proportional to our age.
                            mack
                            HERMES
                            original owner
                            81 XS 1100 LH MNS
                            SPICA
                            78 XS 11E
                            IOTA
                            613-398-6186
                              Agreed. 10 years ago the engines only weighed about 50 pounds.
