Mike,
YES! It can absolutely be done with relative ease WITHOUT removing the engine. I had to enlist the help of SWMBO to help guide the cam chain and hold it up through the passage while I set the head on (the frame makes that a little bit of a bugger but not too bad). Other than that, no other help needed and no other significant issues.
I also had some second thoughts about not changing the rings when I pulled the head and my bike has probably 20k more miles than your Bagger. You could add 100 more items to your list of "SHOULD BE DONE WHILE I'M IN THERE" but where do you stop? Heck the engine is half apart...might as well change; the crank bearings, clutch plates, springs, transmission bearings, oil pump, etc. etc.
Personally, I had to draw the line at the head as head gasket was toast. The head was sitting on a work bench & I had the valve seals in the gasket kit and lapping compound in my tool box. Putting it back on without doing those things would have been silly.
IMPO - If your bike didn't have such nice compression and it also had 75K+ on the ticker that'd make great sense to look at the pistons, rings, etc.
KURT
KURT
The head can be removed and installed with the engine in the bike. do not disturb the pots & pistons. The head was stripped and cleaned and the damaged thread repaired by a machine shop. Valves lapped and new seals installed for a couple of beers and a chicken dinner if I recall correctly.
I had to pull the head AGAIN....and you have to break the cam chain to do it.)
Every set of pipes I have look like nearly total poop.
