Exhausting problem
The list changes. -
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
OK, here's the latest on my exhaust issue.
I've been running my Mac headers with some home made straight through perforated baffle NOISY mufflers. It runs great with them but it rivals Hardleys in exhaust decibels.
Bit the bullet and bought a brand new flare tip Mac 2 into 1 system. The only Mac mufflers with a removable baffle is the flare tip.
So, I put it on today and take a test run...............my stumble a WOT is back. This engine HATES the Mac baffle design. At least these mufflers I can work with and modify the baffles.
I'm going to try and find a small glass pack blank muffler that will slide into these muffler tubes.
Stay tuned.......pun intended.Greg
The list changes.Comment
That should read 4 into 2....old timers disease.Greg
Anyone here have a pair of straight through perforated muffler baffles they might want to get rid of?
Ideal dimensions would be 1 1/2" - 1 3/4" diameter x 16" long.Greg
Nobody?Greg
Maybe something like this would work - 1 3/4" baffleI think I have a loose screw behind the handlebars.
Actually that's exactly what I've been looking at on ebay but at twice the price.
Along with this packing kit..
http://www.ebay.com/itm/290733965492...%3AMEBIDX%3AIT
J & P had a lot of different baffles as well as packing. Best I can do for you, brother - Baffles and stuffI think I have a loose screw behind the handlebars.
Thank you Doug.Greg
Got the muffs done today finally. J &P Cycle is a PITA, only took 30 days to get the original order and they sent 2 this time. SMDH
I've come to the realization that this engine HATES any kind of back pressure. Got 'em al back together with the straight through baffles, except the J&P ones are slightly smaller and the perforation sticks WAY down into the flow, put them on for a test ride...............stumble at WOT is back again haunting me.
Gonna open the J&P ones up some tomorrow and hopefully go in the right direction again.
On the positive side, it sounds GREAT! Got a nice semi quiet glass pack rumble.Greg
On the positive side, it sounds GREAT! Got a nice semi quiet glass pack rumble..
Branthow will METERING RODS clear restricted exhaust?
Maybe I should check the voltage at the mufflers.
I get what Brant is saying... Tune the carbs to the exhaust. As long as it is a rich stumble, he is offering a good thought. Go the other way if it is lean, as you know.Howard
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462Comment
