Exhausting problem
    • 9980
    I went through 3 sets of carbs and half a dozen jet configurations as well as pretty much every other tunable part before I found that it was the exhaust causing the issue since I put this engine in here.
    I pretty much know WTF.
    This engine is out of a Bob Jones 79F parts bike and I've never been into it other than the valve cover and the oil pan but I can tell you for sure it's an "exhausting problem".
    Read all about it here........ http://www.xs11.com/forum/showthread.php?t=44707
      IMO, the "exhausting issue" was the end result of 'highest inch vacuum' setting of mixture screws instead of 'lean drop' method. Possible a pinch to high of actual fuel levels, not float levels, or a step overall to rich with the main jet change. Know the later was done intentionally to least keep a 'to lean' cond. from occurring since you normally roll LD rides on slab at.... lets just say 'a fast clip'.
        • 9980
        GEEZE BRANT!!!!!!! Gimme a break.
          For you.....from me......no break.
            • 9980
            You know as well as I do, IDLE MIXTURE has absolutely NOTHING to do with WOT. Don't be ridiculous.
              • 9980
              Here's the latest on the exhaust.
              Got me a brand new Mac Flare Tip 4 into 1 system because it's the only Mac system other that the 4 into 1 that has removable baffles so I could play with them and modify as needed.
              Put it on a test rode it.......the stumble at WOT was back again so I pulled the baffles out and tried it again. Stumble gone but ear bleeding loud.
              Here's what the baffles that came in it look like. Just like the baffle in the 4 into 1 but there are 2.
              Too restrictive for this particular engine for some reason. Had a 4 into 1 on the green 79 and it ran GREAT with no issues at all. Same carbs, same jetting, basically the same engine but it was a 3H3 and this one is a 2H7.
              This is the first mod on the baffles. A 1 7/8" perforated baffle with a 1 1/2" welded on the end to extend the legth of the muffler case. Both straight through design. This is the 1 7/8" I used in the front, the rear were the ones dbeardslee suggested from JP Cycle.
              Still had the stumble but not quite as bad.
              So, I had another set of 1 7/8" baffles in the homemade set I had been running so I wrestled them out of there, they fought hard but I won. , cut the smaller ones off and welded them on the end of the other larger ones. Packed them in SS wool packing and went for a ride.
              VICTORY
              These mufflers look mean and sound even meaner but are actually only about as loud as my Mac turnouts were.
              Stumble is gone and pulls hard to well over 100mph.
                Good to see and hear you got the exhaust system sorted to keep motor happy now!
                  • 9980
                  That should say 4 into 2. My bad.
                    • 9980
                    Kinda blows the whole "back pressure" theory out of the water doesn't it?
                    Here's some reading for the back pressure is NEEDED advocates......
                      • 9980
                      Update
                      Since modifying the mufflers I've always still had a slight stumble at WOT around 4 - 5K I couldn't sort out. Finally I found the answer!
                      Put in a set of plugs one step hotter plugs and started playing with the air gap. With those plugs and a gap of .035 the stumble is COMPLETELY gone.
                        Good to hear you got the issue sorted.
                          • 9980
                          Spark wasn't hot enough. It came to me laying in bed one evening. Might be why I don't have a wife too. LOL
                            • 5044
                            #43
                            There you go Greg. Go hotter on spark.
