Harley Sportster muffler question
The list changes.Tags: None
I don't know, but I'll make an observation. Those mufflers appear to be setup for a crossover, in which case each cylinder would be using both mufflers at the same time. Maybe they need to be more restrictive when they're setup that way? JATI think I have a loose screw behind the handlebars.
muffs
I have two sets of them without the crossover. They are very loud, and meant to be installed on the same side. I never put them on an 1100. Heard one set on a XS650, very loud.put something smooooth betwen your legs, XS eleven
79 F (Blueballs)
79 SF (Redbutt)
81 LH (organ donor)
79 XS 650S (gone to MC heaven)
76 CB 750 (gone to MC heaven)
rover has spoken
I thought of that too Doug but Rockin'D;s XS is in my garage and it has basically the same mufflers on it except for the opening for a crossover. Looking inside them they look the same.
I tried to take a pic of the inside but it didn't turn out well. About half way through the baffle on the inlet side it's blocked off and there are several rows of tiny holes in the baffle pipe. The outlet looks the same but there appears to be less tiny holes in the baffle.Greg
Originally posted by rover View PostI have two sets of them without the crossover. They are very loud, and meant to be installed on the same side. I never put them on an 1100. Heard one set on a XS650, very loud.Greg
Originally posted by BA80 View Post81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by BA80 View PostI thought of that too Doug but Rockin'D;s XS is in my garage and it has basically the same mufflers on it except for the opening for a crossover. Looking inside them they look the same.
One thing's for sure - if you hook 'em up with the crossover you should have less back pressure than without it. Probably get in the way of the center stand too, though. Okay, that's two things.I think I have a loose screw behind the handlebars.
Doc's bike ran good before it lost compression on one cylinder.
The crossover can't be hooked up with the mufflers on opposite sides of the bike. The orientation of the bracket mounts and the crossover inlets won't allow it. They will have to be blocked.
A freeze plug for an automotive engine should do nicely to plug them.Greg
Originally posted by BA80 View PostDoc's bike ran good before it lost compression on one cylinder.
A freeze plug for an automotive engine should do nicely to plug them.I think I have a loose screw behind the handlebars.
Originally posted by dbeardslee View PostIf they work well on his you'd think they'd work fine on yours too. Freeze plug idea sounds like a good one. You gonna weld 'em in?Greg
Originally posted by Bikes View PostThose are stock mufflers, probly not too loud.......only concern might be rejetting.....try em and see....Greg
Don't some Harley pipes have catalytic converters built into them? These aren't some of those are they?Nathan
Originally posted by natemoen View PostDon't some Harley pipes have catalytic converters built into them? These aren't some of those are they?Greg
A freeze plug for an automotive engine should do nicely to plug them.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
