Harley Sportster muffler question
    Originally posted by natemoen
    Don't some Harley pipes have catalytic converters built into them? These aren't some of those are they?
    Some do, but they'll be marked as having the convertor. And only one in the set will have it.
    Greg, they are fairly restrictive. Harley really choked the stock bikes to get them to meet EPA standards, which is why a muffler change and a rejet is usually worth about 20% more power on these (it should be so easy on a XS...).
    With that said, you're not running a V-twin with an odd firing pattern, so with the smaller cylinders/even pattern it may be fine. And guys have been known to use an extension on a hole saw and cut all/part of that baffle out, gaining power (and noise). If you can figure out a way to reconnect the crossover, it should be worth 3-5 HP...
      Thanks Steve, that's the kind of info I was looking for.
        • 3373
        My 80G with welded on end sections of sportster muffs to replace the rusted out rear sections. Here's the left rear, right side looks the same. Clean looking, no louder than stock and I kept the stock XS crossover.
        [/URL]
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
        • yamtom
          • 275
          • Midland Michigan
          sporty muffs?
          I have sporty muffs on my MNS, cant tell the difference from stock. No adjustment with jets either.
          Bikes Now.
          80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
          79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
          83 Yammi Venture with custom footboards, 20k miles.
          83 Yammi Venture parts bike
          99 Valkyrie shield and bags 37k miles like new
          08 ZX 14 Kawa Ninja 6k miles Sold
            Originally posted by BA80
            Wasn't planning on welding. I'll just find some with a good snug fit, drive them in and spike the edges of the inlet.
            Tack them several places......the weld all the way around or youWILL have leaking pop-fires out exhaust.
