Possibble ignition or starter issue
  • Skuvas
    • Sep 2014
    • 14
    • Carthage, Tenn.
    the blade fuse box Very top one you can see the red wires going to it and the white plug a little further up the wires
    80 XS11
    • Skuvas
      • Sep 2014
      • 14
      • Carthage, Tenn.
      This bike if I have my way is getting a new wiring harness made and installed in the next few months
      80 XS11
        • 9980
        Cool.........thought you abandoned the thread. Ha ha ha.....that tends to piss me off when I take the time to try and help.
        Glad you got it solved.
        It would be a good idea to go through and clean all the connectors and switches on your 35 year old bike. And check your PO's work. Electrical issues are the biggest problem with them simply because spade connectors suck in any automotive application and they are probably all corroded from age.
        • Skuvas
          • Sep 2014
          • 14
          • Carthage, Tenn.
          Yeah I was outside removing the seat and trying to find the elusive main fuse I am glad That we were able to get her up and running though because I am off work for the next three days and my birthday is this weekend and I didn't want to be trapped inside a box !
          80 XS11
            • 9980
            I was trying to read the labels on your fuse panel but they don't say what they are. I moved my main there also as well as the auxiliary (the one glass fuse you still have).
            I saw the top one said 10A, the main should be 30A.
            • Skuvas
              • Sep 2014
              • 14
              • Carthage, Tenn.
              Main is 30A
              then the little paper has the other four listed with the correct amps on them i always wondered why it had four fuses labeled and 5 in the box
              80 XS11
                • 9980
                That's what threw me when I looked at it first.
                At any rate, check ALL connectors for corrosion. It'll save you problems down the road.
                  Originally posted by BA80
                  Looks looks this.........
                  Dat be the one
                    Yeppers, dats the one......pull the fuse mount panel, unplug and meticulously clean all five plug-ins after which add a tad bit of dielectic grease and plug them back together.
