I've got a set of Green Mikes XS coils out in the man cave right now. They've only got about 3k miles on them, but I ditched them in favor of the Dynas. But in retrospect I think most of the trouble I was having was due to the wrong needles being installed, and they worked okay at lower rpms. I could never get them to push to redline, but they'd get close.
If you want to try some hot coils to see how it affects giddyup and cold starting, you can have these. Might even be able to dig up some plug wires for you, but you'll need to use your own caps. I wouldn't recommend using them permanently, but they'll show you the difference hot coils make. And these suckers are HOT - 45Kv worth. You'll need to open up your plug gap to .035, but again, if you want 'em they're yours. And the way I had them installed (cross drilled) you can bolt them right into place with the stock hardware.
