Power loss
Didn't those 79s come with 110 mains on the outside cylinders and 120s on the two inside?No Harry, it started before the pods. I switched to the pods because I've been pulling the carbs so much trying to cure the issue and they are easier to deal with.
I pulled a set of 127.5 jets out of an oddball set of Mikuni carbs I have in the pile-o-parts. I have no idea what they are off of but they have the same style jets. I'll install those and see how it is and if it's too lean I'll start drilling these until I get where I need to be and buy a set that drill size.
My friend Ken here in Tulsa (can't remember his site name) is having a very similar problem with his 80G. I'm starting to think it's a gas supply issue. As in gas station supply.Try your hardest to be the kind of person your dog thinks you are.
Yeah, Harry is right, even though I used to assume Specials were different carbs. I do believe the needle jets are different from #2/3, and #1/4. But, the SF carbs should be 137.5 on the main's, and 42 on the pilot.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
137.5 all across
Yup, the main jets dropped in size to 110/120 in the later carbs, XJs went to a 112.5 all across
Yes, my carbs have needle lets with less air holes in the center. The pilot jets are 42.5 78 -80, 81 went down to a 40, then the XJ went up to a 47.5.Greg
Greg,
The only fuel-related changes I know that occur twice per year at refineries is summer blend / winter blend.
But I'd think if it was a gas station fuel issue change, you'd see a difference with all the different stations you've bought fuel at since this started happening...
Usually if carbs are rich enough to the point they cause a performance issue at certain throttle / load situations, you'll see black smoke out the exhaust when it occurs. But I don't remember riding behind you much on the trip, so didn't notice that.
Bog down is usually fuel related.
Stutter under load acts like ignition.
Bad coils usually get worse as they get hotter, better cold.
Weak ignition would probably want a leaner mixture, wouldn't it?
Sounds like you've tried everything short of swapping coils...
With all the carb swaps, jet swaps, etc., it's the only explanation I can think of why it runs better if you lean it.'82 XJ1100J Maxim (has been sold.)
'79 F "Time Machine"... oh yeah, Baby....
(Sold back to Maximan)
2011 Kaw Concours 14 ABS
"What we have here is a failure to communicate."Comment
Read back through the thread Bob, I've changed coils 3 times. I've changed a LOT of stuff one thing at a time with not a lot of success.Greg
Just tried it with 127.5 mains.
The stutter at WOT in low gear is still there but not near as violent.
WOT in high gear it accelerates smooth up to 85 - 90 then starts to gurgle again.
An improvement but still seems not lean enough. Soon I'll be down to 110's or 120's like the late carbs.Greg
So, I've been following this post because my bike all of the sudden started to have same symptoms. Do you have any definite conclusion as to why the bike is behaving the way it is, or are still in the hypothesis stage?
At first I thought it was electrical, because the symptoms would show up and "fix " itself randomly, but I'm leaning towards fuel starvation now.... My guess is the petcocks or inline filters clogged up.
That's my .02
Nick
1982 Virago 750 (it's alive!)
1979 XS 11 F, Windjammer IV, Samsonite luggage cases(another rescue)Comment
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
Food for thought My bike was running fine good color on plugs good start etc etc but I had for the longest time been getting E0 from a station down the road. Needed gas today and did not want to go the extra distance the opposite way of travel so I go premium gas at Sheets. Now Idle is off an intermittent gurgle and stumble on acceleration and the gas smells more like fuel oil or diesel than gas. And guess what my plugs look a lot like yours now Greg. Me I'm sure its bad gas. New blend of winter crap!!!!!!To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
http://s1184.photobucket.com/albums/z329/viperron1/Comment
That's the direction I'm starting to lean also Ron but in years past I haven't experienced this.
Just finished taking another run on the same course with the filters removed.
The low gear stutter almost gone and I couldn't get it to gurgle in high gear.
Definitely still on the rich side.Greg
If you think it's the gas, here's a little something for you to try. Mix 1-1.5 oz of acetone to five gallons of gas. It will break the surface tension on the gas and make it atomize better. I always run it in Betsy, as well as my lawn mower and chipper. I really notice the difference with the chipper. Without acetone it will bog down on big branches, but with acetone it chews right through them.That's the direction I'm starting to lean also Ron but in years past I haven't experienced this.
Some people will say, OMG! It'll eat the plastic and rubber parts in your fuel system! Which is BS. I've been running it for years without any deterioration of fuel system components. At such a low mixture I don't see it as a risk. But you don't want more than a max of 1.5 oz to 5 gallons of gas. At higher mix rates you start to loose the benefits - one of which is better gas mileage in some cases.Last edited by dbeardslee; 09-23-2015, 11:15 AM.I think I have a loose screw behind the handlebars.
