Power loss
  • jwhughes3
    • 2798
    • Home of the Alamo
    #256
    I have a servicable, if somewhat blemished set of Special pipes Greg.
    Might need a meet up in Oct.
    John
    '81 XS1100H - "Enterprise"
      Originally posted by BA80
      What, and miss the blizzard? We got to experience all 4 seasons in 10 days last trip.
      Free is good, I can afford free.
      Thought your last comment would catch your attention.
        Me too (sort of)
        It took me 6 months to figure out the same thing in my Stihl leaf blower. The spark arrester in the muffler plugged up. I didn't even think about the exhaust at first, but that's what made it run so crappy.
        With all your XS11 experience, it's odd this problem was so hard to find. We all learned from it.
        Congratulations on solving it!
        • ViperRon
          • Feb 2011
          • 1062
          • Woodstock, VA
          #259
          Page 11 post 152 TC winner of chicken dinner.........
          Rodan
          1980 G Silverbird
          1198 Overbore kit
          Grizzly 660 ACCT
          Barnett Clutch Springs
          R1 Clutch Fiber Plates
          122.5 Main Jets
          ACCT Mod
          Mac 4-2 Flare Tips
          Antivibe Bar ends
          Rear trunk add-on
            Hey Greg,
            Okay, I'll dive back in. The exhaust does sound vaguely familiar with regards to it getting clogged? I can't recall if you have worked on the mufflers and the baffles? My MAC 4-1's baffle is a simple louvered pipe design, so not much chance of it getting clogged. But if your baffles were Steel Wool or such, then years of carbon could build up in the mesh to cause a restriction??
            I remember having a Ford T-bird with a 4 cylinder turbo, it was quite peppy. But then it became boggy, wouldn't take much throttle, etc.. Turned out that the innards of the Cat. convertor had broken up, got all turned sideways and such, so not smooth pathway thru the honeycomb structure, and essentially shut down the outflow. Once the Cat. Conv. was replaced, the engine came back to life.
            JAT. T.C.
            OK, YC is the winner. I had dismissed his comment about the exhaust because the baffle isn't removable on the turnouts and they are relatively new. However, I do recall seeing several other bikes with this same system and there's always an area in the center that the chrome is discolored by heat and I never actually made the connection. That's where the baffle is restricted.
            I've been thinking that if a person could bore a hole straight through to the other end of the baffle assembly and insert a perforated baffle, tack weld it at both ends it would relieve the restriction. JAT
            The pipe the baffle is made of is about 1 3/8" ID. Here is what it looks like from the inlet.......
            • dbeardslee
              • 4385
              • Maineville, OH
              #261
              It looks like the existing baffle is just tacked in. I wonder if you ground off the weld if you could pull the old baffle out and just replace it with a different baffle. Or clean the old one and maybe modify it a bit and put it back? JAT
                Except for the fact that the outlet is curved and the inlet has been reduced from 3" to 2 1/4" that would work.
                The only options are doing it as I was thinking or cutting the thing in half.
                • dbeardslee
                  • 4385
                  • Maineville, OH
                  #263
                  I wonder how much trouble it would be to put bonafide baffles in those little mufflers you made up. Those actually look kinda cool. J&P Cycles sells a whole bunch of different baffle inserts.
                    There are some perforated baffles in there but there was only enough room between the inner walls of the tips and the baffle for about 1/4" of SS wool. They sound kinda cool but would be obnoxiously loud for anyone riding beside or behind me.
                    • dbeardslee
                      • 4385
                      • Maineville, OH
                      #265
                      Just tell 'em it's a safety feature.
                      • dbeardslee
                        • 4385
                        • Maineville, OH
                        #266
                        I wonder if fiberglass matting would work any better than the steel wool. JAT
                          I've been looking at these but they are a little pricey and I wold have to come up with something for the outlet.
                          http://www.summitracing.com/parts/wlk-24239
                          • dbeardslee
                            • 4385
                            • Maineville, OH
                            #268
                            Here's some other ones that might look kinda cool. Kinda pricy too, though. It's amazing what some places want for a dang muffler these days. Makes me wonder if Midas can put mufflers on a bike. Motorcycle Exhaust Builder Components
                              I was working at Midas when I built these. Midas I worked at for 14 years right across the street from here where I work now.
                              • dbeardslee
                                • 4385
                                • Maineville, OH
                                #270
                                Do they do motorcycle exhausts? I wonder if they could build you something that swept up a bit to get 'em closer to the footpeg bracket like the stockers.
